Fuel Leak Need Help!!
Old Apr 22, 2008 | 05:02 PM
deadduckky's Avatar
I bought a 1990 4runner with the 3.0 and just replace the fuel pump assembly about 200 miles ago. Now there is gas dripping out of the FRAME on the passengers side right behind the front wheel well. It does not start dripping right away but after its been run for about 10 minutes. So when I stop driving I let the pressure out of the tank by removing the gas cap and this seems to slow down the leaking and then it will slowly stop. I followed the lines comming from the tank and nothing appears to be leaking or even "wet" with gas. I popped the hood to look around the fuel injectors and around and did not see anything "wet" there eaither. I can't find a way to see into the frame to see where its comming from.
If ANYONE has ANY ideas PLEASE let me know!!!
Pictures:
http://www.toyota-4runner.org/showth...217#post315217
Thanks,
Steve
Old Apr 22, 2008 | 05:14 PM
deadduckky's Avatar
I put some pictures up on here...
Old Apr 22, 2008 | 05:28 PM
TOYOTA 1's Avatar
i think it has somthing to do with the fuel return line look on the passenger side wheel well you should see a hose going into the frame its coming out of there!
Old Apr 22, 2008 | 05:37 PM
deadduckky's Avatar
I just went out and looked and I didn't see any hoses going into the frame!?? Someone else told me that there are no lines in the frame, not sure if this is correct or not? anyone?
Old Apr 22, 2008 | 05:52 PM
Froggy93's Avatar
Check the flexible rubber feedline that goes between the end of the hard line and the entrance of the fuel rail. It may have a small hole and may be shooting on to something else making it drip out of the frame rail. I don't believe they have any lines running through the framrail but I could be wrong. now if you had a t100 I'd be certain.
Old Apr 22, 2008 | 05:59 PM
leebee's Avatar
youll have to leave it 'pressurized' to make the leak more noticable. good luck and keep us posted.
lee
Old Apr 22, 2008 | 06:15 PM
wowza025's Avatar
My gas line just started to leak right around that area. There is a plastic clamp that holds the gas line to the frame. Mine rusted at the clamp, and now only leaks for a little after the engine has been run. I slowed mine down for now the wrong way, using gas tank sealer on the gas line. I dont recomend this, it doesnt work that well. I just havent had a chance to replace the whole line, and am not looking foward to it. Check there? Hope this helps. Good luck.
Old Apr 22, 2008 | 06:26 PM
mt_goat's Avatar
If it really is coming from inside the frame, there IS one line that goes into the frame. The dump hose from the evap canister goes into the frame in that same area. If for some reason your evap can is filling up with fuel it would drain out into the frame.
Old Apr 22, 2008 | 06:28 PM
TOYOTA 1's Avatar
i dont think there is any lines running threw the frame rail, i think there is a rubber line that is just shoved in a hole in the frame and ends a few inches in there. its the "overflow line" i think. im not shure but i remember someone having a similar problem and it was leaking out of that hose. i dont realy remember, good luck!
Old Apr 22, 2008 | 06:29 PM
TOYOTA 1's Avatar
ahhh that is what i was talking about thanks for clearing that up for me goat!
Old Apr 22, 2008 | 06:43 PM
mt_goat's Avatar
Old Apr 22, 2008 | 06:47 PM
deadduckky's Avatar
It is comming out of the frame for sure and thats the only place that is "wet" I'll have to check that out...is this picture from a 4runner? THANKS!!
Yoda's Avatar
This happened to us. We accidently switched the fuel vent and fuel return line. It filled the vapor canister with liquid fuel, and it ran out the drain tube into the frame.
Old Apr 22, 2008 | 06:52 PM
mt_goat's Avatar
That's a pic from my 93 pickup.
Old Apr 22, 2008 | 07:24 PM
deadduckky's Avatar
I just checked it and you were right, the canister is overflowing.... Thanks!
I'm assuming that the two hoses mentioned above got switched, I bought this truck as a project and the tank was allready off...
Thanks guys!!
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
raptor510
Feb 17, 2017 07:11 AM
nick b
Jul 11, 2015 04:38 AM
Avenged
Jul 9, 2015 07:55 AM
