Question on 63" Chevy Spring Swap
Old Apr 22, 2008 | 09:05 AM
sethmcalister's Avatar
I just got my chevies in yesterday. they're awesome but, my driveshaft is vibrating pretty good. currently it is just a stock 89 with my chevies and no other lift. has anybody put in a pinion shim to correct the angle? if so, where did you get them and how much of an angle?
also, does anybody know if it makes a difference which way the lengths to the center pin are? for instance should the 30 3/4" be going from center pin to the rear of the truck or to the front of the truck?
Old Apr 22, 2008 | 09:08 AM
dirtoyboy's Avatar
Have you looked in the Pirate chevy swap FAQ?
Are you running a cv in the rear?
You can use shims or drop the crossmember. Dropping the crossmember would be a quick way to find out if the problem is angle related or balance related. Some pics of your angles might help
Old Apr 22, 2008 | 01:23 PM
Apology for the newbie comment, but, I don't believe it is a CV style driveshaft. It is just my stock driveshaft. How would lowering my crossmember take care of the driveshaft vibration?
Old Apr 22, 2008 | 01:28 PM
4Crawler's Avatar
Measure the driveshaft angles and it is easy to make a shim to correct the angle if needed:
- http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ1
As far as orientation, the military wrapped spring eye goes into the forward frame mount.
Old Apr 22, 2008 | 01:44 PM
dropzone's Avatar
Fossilized
http://www.pirate4x4.com/forum/showt...threadid=20665
Old Apr 22, 2008 | 03:20 PM
LTrunner's Avatar
check your u-jionts and your trust angle...
Flying91
45
Apr 11, 2024 04:39 PM
Coreyr384
Jul 10, 2015 11:13 AM
Nickdigg
Jul 7, 2015 06:04 AM
wilbertd
Jul 6, 2015 07:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
