spark plug connector grease !?!
Old Apr 23, 2008 | 06:22 PM
scuba's Avatar
so im at o'rielys buying a set of ngk plugs and some wires
Trust me, if i had money for toyota plugs and wires i would deff go get those.
but
i decide to pick up some of this stuff.
anyone else believe in using it??
Old Apr 23, 2008 | 06:41 PM
shancerlelby's Avatar
its called dielectric grease. keeps water out of electrical connections and such. works wonders for not corroding and keeping connectors clean and easy to disconnect etc. i think it works awesome.
Old Apr 23, 2008 | 06:50 PM
Jay351's Avatar
I use dielectric grease all the time. Smear some on your battery posts to keep them clean.
Old Apr 23, 2008 | 06:58 PM
DCYota's Avatar
Yes, by all means you should use it each time you change out your plugs and/or wires. That's what it's for. I also use it on my battery posts like Jay mentioned above.
Old Apr 23, 2008 | 07:04 PM
rdlsz24's Avatar
Are you talking about anti-seize for the threads or dielectric grease or whatever it's called for the boots? I think both are good to use. I don't pay $1 for those little packets at the counter, though. You can buy a larger tube for not much more and then you have it.
Rob
Old Apr 23, 2008 | 09:36 PM
scuba's Avatar
so should i smear the stuff on the ends of the plugs too, and the wire between the coil and distributer ?
Old Apr 23, 2008 | 09:49 PM
shansethp's Avatar
just put it on spark plug where connects to the wire, also every time i have bought wires they came with little pouchs of the stuff in the box so i didn't have to buy it extra!
Old Apr 24, 2008 | 05:13 AM
dirtoyboy's Avatar
Make sure you coat those plug threads in anti-seize
Old Apr 24, 2008 | 05:45 AM
zlathim's Avatar
No don't put the dialectric on the end of the spark plugs, certainly not in the electrode area. Others have mentioned putting anti-seize compound on the threads to facilitate easy removal in the future. Anti-seize is sold at all auto parts stores.
Old Apr 24, 2008 | 07:03 AM
Brenjen's Avatar
Just coat the rubber boot with your finger along the inside lip or around the ceramic body of the plug, either way will work & it will seal out moisture & facilitate boot removal in the future. Don't glob it on.
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
cars-guy
Jul 11, 2015 07:51 PM
