86 front diff into a 94 4runner
Old Apr 29, 2008 | 04:00 PM
Booosted Supra's Avatar
Question 86 front diff into a 94 4runner
Is this possible? everything looks the same but on the 94 diff i have 2 vacuum lines and a sensor coming off of it and im not quite sure what they are for, can everyone enlighten me on this? yes ive searched to. thanks in advance
Old Apr 29, 2008 | 04:09 PM
bigt's Avatar
the vaccum line are for shift on the fly you should be able to use it but might hav to come to a complete stop before going into 4wd
Old Apr 29, 2008 | 04:28 PM
Flash319's Avatar
That is for your auto disconnect. You will need to have manual hubs or you will be turning the whole front end all the time.
Old Apr 29, 2008 | 07:51 PM
yeah ive had manual hubs on my truck for a long time i just never noticed what that was for, basically my front case is toast and i have a friend with a good one whos going SAS and has his laying around so i was curious of what i had to do
Old Apr 29, 2008 | 07:59 PM
cujeeprs's Avatar
I just did a swap of an 86 front diff into my 94 truck, and it works great. I was doing a gear swap and didn't want my truck to be down very long since it's my daily driver. I had the 86 diff and installed my new gears and bolted it in place of the 94. I also installed the manual hubs from the 86 and plugged the vacuum lines. It works great, and I've had no problems since the swap.
Old Apr 29, 2008 | 08:01 PM
nice! did your existing 94 axles work?
Old Apr 29, 2008 | 08:11 PM
cujeeprs's Avatar
Axles bolted right up. No problems. The only headache I had was getting the diff back in place by myself. Took me an hour to get it in place. That thing is heavy! I also knocked out 3 of the studs on each axle to make it easiers to get the diff back in, that was a big help. I just put them back in once everything lined up. I've taken the truck out a few times on some short trails since the swap, and everything works just like it should. I just wish I had stuffed a locker in it while I had it out.
Old Apr 29, 2008 | 08:23 PM
good stuff, thanks for the info i appreciate it
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
toyoda8488
Jul 5, 2015 10:18 PM
HRDC0R19
Jul 5, 2015 06:43 PM
