Driveshaft question
Old Apr 28, 2008 | 09:22 PM
85.5Yota's Avatar
Driveshaft question
I just did the SAS on my truck and im wondering what i should do for the front driveshaft. Is it possible to just add longer tube to the stock driveshaft and still have enough slip yoke? i am running the AllPro Front spring Hanger with 5" Springs and 5" shackles. Im not sure what to run. I would like some help from Someone with Experience, or someone that has done this a few times already. thanks Joe............
Old Apr 28, 2008 | 09:26 PM
80W90's Avatar
http://infohost.nmt.edu/~jscarbro/driveshaft.htm
Old Apr 28, 2008 | 09:27 PM
fillsrunner4's Avatar
Local shops are pretty cheap but you want to make sure they use good metal as in strong. My buddy went to a shop and the shaft was so thin that I could chew it up with my teeth if I wanted
Old Apr 28, 2008 | 09:38 PM
85.5Yota's Avatar
so you think i could use the same slip and just add length to the tube?
Old Apr 28, 2008 | 10:01 PM
Pretty much. Maybe even add a bit more support to add some extra strength if you wanted too.
Old Apr 29, 2008 | 05:03 AM
Kaptain's Avatar
Stock slip (5 inches) isn't going to be enough up front. I'm using atleast 6+ inches of slip up front with flexy 3 inch springs... Either get a long travel splined driveshaft (Trail-Gear, Marlin, All-Pro) or make a square one for cheap
Old Apr 29, 2008 | 05:07 AM
dirtoyboy's Avatar
x2...you HAVE to have a long slip....If you just re-tube the stocker you will be dropping shafts
Old Apr 29, 2008 | 05:29 AM
Crawdad's Avatar
Entirely right, don't cheap out on the driveshaft, or you will not have a good time. I've seperated a shaft on the trail, and while it's relatively easy to get back in, it's not fun to stop and do it.
I would get a good local shop to make you a long-slip shaft. Probably looking at around $150.
Old Apr 29, 2008 | 05:44 AM
Kaptain's Avatar
Good luck finding a shop that has anything like this; they will just stare at you when you ask them. Long splined shafts are expensive especially from a shop - just go through one of the vendors and take that along with your current shaft and they will piece it together.
If you're going this far you will need to clearance the CV so that it can operate at more of an angle (especially if your just running a single t-case - you may be better off with just single cardon (U-joints) at both ends)
Old Apr 29, 2008 | 05:55 AM
Crawdad's Avatar
I reckon I've just had good luck... I live in the south, and all the driveshaft shops around here are used to making custom stuff for the offroad community. It's worth a try to call around locally, anyway.
Old Apr 29, 2008 | 10:48 PM
Ya sorry read it wrong youll need more slip for sure at least six but I would recomend more that that
Old Apr 30, 2008 | 03:25 AM
Kaptain's Avatar
I'm currently running a front DS with 12 inches of spline (Trail-Gear). All-Pro and Marlin also has them with 8 inches, which I consider the minimum that you'll need.
Old Apr 30, 2008 | 08:35 AM
Ide say go with the 12 if you can
Old Apr 30, 2008 | 08:48 AM
dirtoyboy's Avatar
My local shop made me go to the steel store and get the tube myself.....I thought it was rather strange.....
I would recommend Tom Woods or Jesse at High Angle
Old Apr 30, 2008 | 11:00 AM
Jesse at high angle drivelines is a great guy and sells well built drivelines. I highly recomend them same as Tom woods
BTW dirtoyboy thats pretty funny a shop made you get the steel but I guess then you know the strength of it. My buddy bought a driveline from a shop and told them it was for rock crawling and they made it out of I kid you not 1/16" steel. It bent like a pretzle
4x4-runner
Apr 18, 2017 09:08 PM
mussy01
Dec 13, 2016 08:20 PM
Tonetrk
Aug 6, 2015 10:06 AM
gillesdetrail
Aug 3, 2015 04:43 PM
Sr5crawler
Jul 31, 2015 12:32 PM
