Changing rear ends
Old Apr 23, 2008 | 01:42 PM
Crawdad's Avatar
Changing rear ends
I need to pull my rear third member out. I know pretty much what I have to do, but I'm told that it is possible to pull the axles out without disassembling the brakes - just take off the 4 bolts on the backing plate, undo the brake line, and slide the axle out. Is there any truth to this, or am I going to have to disassemble the rear brakes?
Old Apr 23, 2008 | 01:46 PM
eric-the-red's Avatar
It's true, you don't have to remove the drums. In fact you don't even really have to remove the wheels. Don't forget to remove the parking brake cable as well as the brake line.
And it's not a good idea to let the axle rest on the seal, completely remove them. Otherwise you'll probably end up with a leak. Maybe a good time to even change the seals.
Old Apr 23, 2008 | 02:25 PM
Crawdad's Avatar
Great info to know, thank you!
Old Apr 23, 2008 | 02:51 PM
tc's Avatar
tc
x2, although I'm not sure how you would undo the ebrake cable without taking off the wheels...
Old Apr 23, 2008 | 02:58 PM
Jay351's Avatar
x2
It took me longer to unbolt the 3rd then to remove the axle shafts.
Old Apr 23, 2008 | 03:01 PM
Gonzo4Runner's Avatar
Access to the e-brake cable is easy if you have wheels with less back spacing, such as 3.75 in or less.
Personnally, I would remove the wheels otherwise the axle w/wheel attached might be too heavy to handle easily, especially for re-installation.
Old Apr 23, 2008 | 03:54 PM
Sawzall
This is my 2000th post, do I get a prize
Old Apr 23, 2008 | 05:03 PM
javadoody's Avatar
Sawzall
yeah, a sawzall blade. a red one.
Old Apr 23, 2008 | 09:23 PM
Steveh29's Avatar
I always change the axle seals when I pull out the axle shafts. If I don't it will for sure start leaking on me. They're so cheap it's not worth the hassle of having to pull it back apart. Another helpful tip is I'll take a couple of vacuum plugs and put them over the brake lines when I undo them. Keeps the fluid from leaking out.
Old Apr 24, 2008 | 05:07 PM
BigWavePaul's Avatar
Lightbulb Pic Link
Write up link
icentropy
Sep 16, 2020 02:47 PM
icentropy
Jul 11, 2015 07:21 AM
toyoda8488
Jul 5, 2015 10:18 PM
HRDC0R19
Jul 5, 2015 06:43 PM
