Changing rear ends
I need to pull my rear third member out. I know pretty much what I have to do, but I'm told that it is possible to pull the axles out without disassembling the brakes - just take off the 4 bolts on the backing plate, undo the brake line, and slide the axle out. Is there any truth to this, or am I going to have to disassemble the rear brakes?
It's true, you don't have to remove the drums. In fact you don't even really have to remove the wheels. Don't forget to remove the parking brake cable as well as the brake line.
And it's not a good idea to let the axle rest on the seal, completely remove them. Otherwise you'll probably end up with a leak. Maybe a good time to even change the seals. |
Originally Posted by eric-the-red
(Post 50812993)
(Post 50812993)
x2 :D
It took me longer to unbolt the 3rd then to remove the axle shafts. |
Originally Posted by tc
(Post 50813050)
x2, although I'm not sure how you would undo the ebrake cable without taking off the wheels...
Personnally, I would remove the wheels otherwise the axle w/wheel attached might be too heavy to handle easily, especially for re-installation. |
(Post 50813050)
:jk: This is my 2000th post, do I get a prize |
(Post 50813113)
Sawzall
I always change the axle seals when I pull out the axle shafts. If I don't it will for sure start leaking on me. They're so cheap it's not worth the hassle of having to pull it back apart. Another helpful tip is I'll take a couple of vacuum plugs and put them over the brake lines when I undo them. Keeps the fluid from leaking out.
Pic Link
Write up link
