How many bolts?
Old Apr 25, 2008 | 04:59 PM
DanStew's Avatar
How many bolts?
I am pulling the engine and want to know how many bolts there are holding the 5 speed tranny bellhousing to a 22re? I want to make sure i got them all and the manual doesnt really show "how" many there are.
Thanks
Old Apr 25, 2008 | 05:08 PM
bigt's Avatar
i would also like to know as im pulling my tranny tommorow as i just got my new tranny jack together \m/
Old Apr 25, 2008 | 07:23 PM
fillsrunner4's Avatar
I believe its 9 bolts.
Old Apr 27, 2008 | 02:44 PM
mudtoy1986's Avatar
ill go look at the engine i just pulled its still hanging from the chain fall
Old Apr 27, 2008 | 02:47 PM
DeathCougar's Avatar
-4 bolts holding bellhousing to block
-4 bolts holding support brackets to bell housing
-2 bolts holding starter on
So 10 Total.
Old Apr 27, 2008 | 02:51 PM
mudtoy1986's Avatar
ok there are 4 17mm2 at the top bellow the valve cover and one on each side at the bottom of the block there are 4 14mm bolts they are bolted to the supports that are on the lwer side of the block also the 2 15/14mm bolts that hold the starter on btw one of the 17 mm bolts at the base of the block are behind the clutch slave cylinder
hope this helps
Old Apr 27, 2008 | 02:52 PM
mudtoy1986's Avatar
oopps someone got it before me
Old Apr 27, 2008 | 02:57 PM
And I got it by memory
Old Apr 27, 2008 | 04:42 PM
DanStew's Avatar
Well i got them off. So who has accidentally NOT put the top botls back in? Would it make a differnence if they were not used?
Old Apr 27, 2008 | 04:54 PM
I wouldn't suggest that. Quick way to break things.
Old Apr 29, 2008 | 04:50 PM
mudtoy1986's Avatar
yeah i would say that toyota put those bolts in the top for a reason lol
Old Apr 29, 2008 | 05:09 PM
Luvmeye22re's Avatar
Ditto, there is a lot of torque flying around in that little bellhousing.
Old Apr 30, 2008 | 05:13 AM
dirtoyboy's Avatar
Don't feel bad! I did the same thing last time I dropped a tranny. Stabbed it..then went to bed...came out the next day and forgot about the top 2 bolts
Luckily it only takes a few minutes to drop the crossmember and tilt back the bellhousing
some drunk guy
Aug 3, 2021 06:09 PM
Zach_trun
Jan 22, 2020 04:42 PM
mistershmi
Jan 5, 2016 11:07 AM
JUICE222
Oct 13, 2015 08:50 AM
JookUpVandetti
Sep 24, 2015 08:56 AM
