How many bolts?
How many bolts?
I am pulling the engine and want to know how many bolts there are holding the 5 speed tranny bellhousing to a 22re? I want to make sure i got them all and the manual doesnt really show "how" many there are.
Thanks
Thanks
ok there are 4 17mm2 at the top bellow the valve cover and one on each side at the bottom of the block there are 4 14mm bolts they are bolted to the supports that are on the lwer side of the block also the 2 15/14mm bolts that hold the starter on btw one of the 17 mm bolts at the base of the block are behind the clutch slave cylinder
hope this helps
hope this helps
Don't feel bad! I did the same thing last time I dropped a tranny. Stabbed it..then went to bed...came out the next day and forgot about the top 2 bolts
Luckily it only takes a few minutes to drop the crossmember and tilt back the bellhousing
some drunk guy
Aug 3, 2021 06:09 PM
mistershmi
Jan 5, 2016 11:07 AM
JookUpVandetti
Sep 24, 2015 08:56 AM
