inner rear view mirror removal?
Old Apr 21, 2008 | 10:03 AM
cederrowe's Avatar
" update" sunroof question?
Trying to remove my sunroof motor to check the cable and using the FSM it says to rmove the headliner and remove the inner rear view mirror. I cant get the cover off to accses the bolts, does it just pry off? No were in the FSM does it show removal of this piece just says remove it? Any help would be greatly appreciated. Don't want to break the inerior light mirror cover in the process.
Old Apr 21, 2008 | 10:06 AM
swaycleveland's Avatar
i just swapped mirrors in my rnner it pops off then you can see the screws
Old Apr 21, 2008 | 10:07 AM
im thnking about it now i think i popped off the light covers and the bolts where under those
Old Apr 21, 2008 | 10:08 AM
dirtoyboy's Avatar
Yes, it just pops off..I usually use a small screwdriver and pry it off
Old Apr 21, 2008 | 10:18 AM
cederrowe's Avatar
The whole cover that has the light covers? I'm prying on it pretty hard and its not budging, I can see two bolts under a small cover I popped off right at the base of the mirror but cant accsess them untill the whole outer cover is off.
Old Apr 21, 2008 | 10:27 AM
aviator's Avatar
With that small cover off you want to carefully wedge your screw driver between the metal part you can see and the plastic cover and pry down gently but firmly on the one side and then the other. This will "pop" the cover out of the catches at the back and you'll then be able to pull it off the rest of the way. These are tight catches so don't be afraid to put a little muscle behind it, but only "pry until it pops" if you go too far on one side you might crack the cover.
Old Apr 21, 2008 | 10:37 AM
cederrowe's Avatar
Ok thanks guys got it! Now the bad part, the gear on the motor isnt turning when the motor runs. Off to you pull it auto parts!
Old Apr 21, 2008 | 12:00 PM
just a 22re's Avatar
thats just a striped mount for the gear on the shaft take it off and weld it all done!!!
Old Apr 21, 2008 | 02:39 PM
cederrowe's Avatar
ok back from u pull it auto parts with new motor. Installed it and the motor wont turn the cable....alot of rust on cable. I want to help it with my hand and while spraying lithium grease in there but have a ? Is this a sunroof that goes up and on top of the roof or is it a sunroof that drops down inside the body? Thanks
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
lledwod
Aug 30, 2016 01:03 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
andrewtexas123
Jul 14, 2015 04:29 AM
