Jet Chips Power Programmer
Old Apr 27, 2008 | 09:54 AM
HippieRunner's Avatar
I've been doing a little serching on the web and Yotatech for upgrades to the 3VZE 3.Slow. and most people are talking headers back overhaul exhuast, and other obvious upgrades. But I was wondering if anyone has bought the Power Programmer from Jet Chips and if so how well has it worked out for them, or any other chip mod upgrades I'd like to hear how they worked out. Thanks
Old Apr 28, 2008 | 05:56 AM
Bumpin' Yota's Avatar
Its been pretty well confirmed EVERYWHERE ive seen - they sell junk that does absolutely NOTHING.
Old Apr 28, 2008 | 07:56 AM
mt_goat's Avatar
No one (that I know of) has yet to figure out a way to reprogram the original Toyota ECU programing. The source code is a closely guarded secret by TM. You might have better luck buying the recipe for Coke.
Now piggy back computers are out there, as well as stand alone ECUs. From what I've seen the open loop programing on the Toyota ECU is already pretty rich, unless your thinking you'd like it to be leaner to save MPG. It runs rich at WOT to protect the engine, at the expense of MPG.
Old Apr 28, 2008 | 08:06 AM
X-AWDriver's Avatar
The 3.0 is kinda hopeless when it comes to upgrades and you'll spend a lot of money to see maybe 10whp with exhaust,headers,intake,etc.
A 3.4 swap is cheaper in the long run if you want a real power gain.
Old Apr 28, 2008 | 08:08 AM
mt_goat's Avatar
Amen.
Old Apr 28, 2008 | 08:41 AM
Actually after some though I know how the JET chip works.
It works through weight reduction. It reduces the overall weight of your wallet significantly thereby allowing your car/truck to go faster!
1. Save 10 large
2. spend 500 bux and put a 150 wetshot on the 3vze
3. Use 150 wet shot on 3vze.
4. Create hole in block with rod*
5. IF unable to create hole, change jetting for a 300 dry shot and repeat step 3.
6. Rip out engine/tranny and replace with a H/C/I LS1 and 4L65e.
7. Complete swap then go "WEEEEE!!!!" were ever you drive.
*Block and rod are interchangalbe with piston and headgasket, etc.
Old Apr 28, 2008 | 08:53 AM
mt_goat's Avatar
LOL, welcome to YT Hippie We do have fun here.
Old Apr 28, 2008 | 09:21 AM
TOYOTA 1's Avatar
1. Save 10 large
hahahah good one.
Old Apr 28, 2008 | 09:46 AM
Belize Off Road Team's Avatar
As bad as everyone makes the 3.0 sound right now. the real answer is take damn good care of your motor and when their 3.4's get tired, your 3.0 will be nice and smooth. right now my 3.0 is better dyno tested better than a:
95 3.0 262,573miles
01 2.8 diesel 153,095miles
out of those 2 dynamometer tested along mine, i put out more whp(121) and more MPG. so for power i clean my K&N every 6 months. i have no cat or muffler. and i change oil and all other fluids as much as needed. my motor still sounds like it was made yesturday.
playig with an ECU is not a good idea to begin with for any vehicle. but if you want to gain real power, go to japan. find a 3.0 petrol specialist who knows how to crack the ECU...it is possible.
Old Apr 28, 2008 | 11:00 AM
MonsterMaxx's Avatar
+ 1
the Jet thing is worthless, if you really want to do a 'computer' do the Megasquirt. You'll be $1k into it when you get there, but will have full control over fuel and timing.
Having said that, $1k would put you half way there to a 3.4 (if you DIY) so I don't recommended doing anything to the 3VZE other than run it stock until it quits, then swap.
chukarhunt
Dec 8, 2019 11:39 AM
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
