toyota 4runner 87 problems
Old Jul 6, 2010 | 06:10 AM
toyota girl's Avatar
Hi i need someones help i just bought a toyota 4runner 87 with a 22re motor and i'm having problems with it. after a driving it for a while and the motor get to it's normal temperature it does not want to get any speed i have to wait till the motor cools down and it working good again. I have replace the fuel pump and the fuel pump strainer and the same problem continues. i have no problem with it turning on. please help me Tags:
Old Jul 6, 2010 | 07:35 AM
thook's Avatar
How old is the fuel filter? Does it seem to have any problems idling? And, other than having problems getting up to speed, is there any hesitation or momentary cutting out?
Old Jul 6, 2010 | 08:02 AM
Unhappy
yes i did replace the fuel filter, no that the only problem
Old Jul 6, 2010 | 08:15 AM
DeathCougar's Avatar
Several things to check, and really we don't have much info to go on.
At ths point it could be trans related, rear end, engine, electrical, etc etc etc.
Assuming everything on the truck is OEM and in correct locations and operating ranges, I would start by getting an FSM and testing things like the TPS, AFM, and related electrical items.
Old Jul 6, 2010 | 08:34 AM
thook's Avatar
Okay, well you said,"once the motor is up to temp" and "you have to wait for the motor to cool down". Is it trying to overheat? If not or if so, this is still a good indication the problem is engine temp related. Could be the O2 sensor.
arlindsay1992
Jan 23, 2024 01:34 PM
vasinvictor
Jan 20, 2016 12:39 PM
JaredL
Jun 16, 2015 04:47 PM
