getting a deal on 1993 pickup
Old Jul 6, 2010 | 06:44 PM
mikehinthehouse's Avatar
Hey guys havnt been around for a while hope all has been well, long and short of it a friend of mine has a 1993 2wd truck with 22re and a 5 speed, he said its got a knock in the motor and is selling it to me for $300 yes I said $300 i am so excited I think i might pee myself! He just put a new clutch in it too!!! This will be my commuter vehicle to work...My ? to yall is worst case scenario i will just change the motor if i discover its a goner.. where is a good place to find a new/rebuilt/used motor? Other than a u pull it junk yard i have checked local ones and had no luck so online I go.
thanks in advance
Old Jul 6, 2010 | 06:59 PM
conrad's Avatar
$300 bucks that's a steal! Congrats! Post pics when you get it.
Old Jul 7, 2010 | 01:05 PM
pruney81's Avatar
Oregon engine builders or putney's custom machine are two that come to mind for rebuilt 22re's
Old Jul 7, 2010 | 01:19 PM
iamsuperbleeder's Avatar
if it's just got a knock, you could probably do a $150 or so engine overhaul during the course of a weekend, and have a $450 truck
Old Jul 7, 2010 | 01:23 PM
norcal707's Avatar
nice deal....post some pics...
Old Jul 7, 2010 | 02:06 PM
By overhaul do mean a rebuild kit?
Old Jul 7, 2010 | 02:43 PM
you got it
they're VERY simple engines to rebuild
all you'll need is a good set of metric sockets and a torque wrench, and you can pretty much rebuild the entire truck
check out engnbldr for good rebuild kits
Old Jul 8, 2010 | 02:01 PM
im pretty mechanically inclined, i dont know if i am enough to rebuild tho... I can def swap motors with no problems.
thats why i was trying to find a place that sells rebuilt motors
Old Jul 8, 2010 | 02:28 PM
norcal707's Avatar
so???? have you bought it yet? pics?
Old Jul 8, 2010 | 04:07 PM
pickn it up tommorow Norcal will def post pics! im excited... this will be a good truck for me. I commute about 80 miles both ways to work and am racking alot of miles on my
4runner. Not to mention how dirty it gets and the rock chips and so on. So this lil truck will be a blessing!
Old Jul 8, 2010 | 08:12 PM
Nogarage's Avatar
You can do it. Easier than the 4WD. Timing chain and guides, rod and main bearings, oil pump, water pump. Anything else? Done. No more knock, quiet and smooth running engine, good mpg's.
Old Jul 9, 2010 | 10:11 PM
norcal707's Avatar
so any updates?/
Old Jul 10, 2010 | 07:46 AM
well here she is... I was mistaken on the year it is a 94. It has a knock at idle only cant hear when driving. and it idles real rough... ac blows cold cold. Im not sure what im gonna do about the knock yet... Im exploring options.. I just dont trust myself rebuilding it. I would probably mess something up and have to get it done again.... at any rate here are the pics as promised
Old Jul 10, 2010 | 12:34 PM
norcal707's Avatar
nice truck mike.....so what are you going to do?
Old Jul 10, 2010 | 03:15 PM
1st thing is figure out where exhaust leak is hopefully it's just a gasket and not a cracked manifold. Either way it's pretty loud I'm gonna fix that so I can really hear motor. I think I hear a knock but it's hard to tell. So that's 1st on the list
Old Jul 13, 2010 | 01:31 PM
stackedyoda's Avatar
the knock might just be a manifold gasket, i had a gasket from 1 cylinder on my cummins not seal and it was loud enough i couldn't turn the radio up to drown it out in the cab
and by the way, i got a deal like yours, a 93 4x4 22re for $500 from a junkyard, needed ground wire cleaned and fuel lines
Old Jul 13, 2010 | 07:50 PM
Hopefully I can get some time this weekend to work on it and see what goin on with it. Will keep updated. That's a sweet deal for a 4x4! Wish mine was but it will serve it's purpose
Old Jul 14, 2010 | 11:48 AM
ya, if i was somewhere that didn't get much snow i would probably have a 2wd as a driver
Old Jul 14, 2010 | 05:28 PM
angrydogtattoo's Avatar
I have two 2wd DD, one for me, one for the wife, but yeah winters suck, even with 200lbs of sand in the back, still not fun
Old Jul 14, 2010 | 05:35 PM
yotamonsta-'s Avatar
hey mike you did get a steal on that truck man nice!!! But yea i would def try the exhaust gasket first when i put my motor in i had the same prob and it was exhaust shooting out the back by the fire wall. it sounded like a real bad knock. if it is more of a tapping you can always check the valves and adjust deff wont hurt.... good luck man nice truck for 300$
