both signals on at once??
Old Jul 13, 2010 | 04:03 PM
flashkl's Avatar
My buddy was driving behind me the other day and noticed that when I turn a directional on both my blinkers flash as if I have hazards on...except the correct one is normal brightness and the one that shouldnt be flashing is really dim. These are aftermarket LED lamps that have combined brake lights/turn signals. The front blinkers are completely fine. Anybody have any ideas or should I go get my truck exorcised?
Old Jul 13, 2010 | 05:25 PM
swampfox's Avatar
i have read that leds take a differant type of flasher.you might also check the grounds.
Old Jul 13, 2010 | 06:35 PM
angrydogtattoo's Avatar
x1 on checking the grounds
Old Jul 13, 2010 | 06:40 PM
toyminator2000's Avatar
Grounds
Old Jul 15, 2010 | 02:01 PM
flashkl's Avatar
there's one ground for each tail lamp assembly, correct?
Old Jul 15, 2010 | 02:27 PM
iamsuperbleeder's Avatar
do you have a trailer wire harness installed?
could be faulty; might want to try removing it and seeing what happens
when I installed the LEDs in my tails with my trailer harness, there was feedback through the system and the blinkers caused the brake lights on both sides to faintly flash as well. I just dealt with it because it wasn't all too noticeable in my case
Old Jul 15, 2010 | 02:40 PM
flashkl's Avatar
^^that sounds spot on. I prolly just didn't notice it til now cause it was so faint
Old Jul 15, 2010 | 03:57 PM
Yeah with normal filament style bulbs, you'll never notice it, because the filament takes so many watts to burn and be visible. But since the LED's take practically no wattage at all to light up, the light bit of feedback that seeps through the trailer light control box becomes apparent, and they'll light up faintly. The reason for the feed back is because the way the 4-wire trailer harness lights the brake lights, it simply signals to light both turn signals at the same time. So in the control box, the left and right turn signals are tied together in the circuitry somewhere, and it's because they're tied together that you'll see the feedback of both left and right to light faintly.
IF you want to get in depth with it, you can try to break it down into what the basic coding for a trailer brake controller might look like
:Inputs - GROUND, TAIL-IN, BREAK-IN, LTURN-IN, RTURN-IN (5 wires leading into the control box)
:Outputs - GROUND, TAIL-OUT, LTURN-OUT, RTURN-OUT (4 wires leading out of the control box and to the trailer; notice the loss of the BREAK signal)
:GROUND carries through; same on both ends
:if (TAIL-IN = on) then (TAIL-OUT = on) (when you turn the lights on in the truck, the trailer lights light dimly, as the tail lights on the truck do)
:if (LTURN-IN = on) then (LTURN-OUT = on) (when the left turn signal on the truck flashes, the left turn signal on the trailer flashes)
:if (RTURN-IN = on) then (RTURN-OUT = on) (when the right turn signal on the truck flashes, the right turn signal on the trailer flashes)
:if (BREAK-IN = on) then (LTURN-OUT = on & RTURN-OUT = on) THIS is the key point where both left and right sides are tied together and causes both sides to light)
Sorry to get geeky on you there
But in an ideal world, there would be NO feedback through the trailer harness, and I'm sure there's plenty of them out there that do in fact have zero feedback (it's quite easy to solve with a simple set of diodes ), but some of the less expensive converter boxes will have the feedback, and the LED bulbs in the truck simply show the feedback
Old Jul 15, 2010 | 04:04 PM
B4Runner's Avatar
Where the hell did this kid come from?!?!
Old Jul 15, 2010 | 04:07 PM
hehehe
Old Jul 15, 2010 | 04:11 PM
flashkl's Avatar
that makes so much sense... it's not like I ever tow anything anyways, I'll jut pull the harness out
kawazx636
Oct 6, 2021 03:03 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
calderp
Nov 16, 2015 02:49 AM
Scotttekoch
Sep 28, 2015 10:30 PM
Boomer8404
Sep 24, 2015 01:12 PM
