strange power problem
Old Jul 11, 2010 | 11:27 AM
backandbigger's Avatar
I have an odd ball problem. When ever I start the truck up it runs fine, shortly after it feels like the power cuts out. Its as though the spark is good and then goes to crap. I tested this out on the road by turning my ignition off and then back on while in gear. Afterwords, I'll give it gas and it sounds solid then a few seconds later its like the power just drops out of it.
The setup is a 22r with a weber 32/36. The coil has been change to a accell super stack performance coil. I checked the resistance on the coil and its on par with a new one.
This has gotten progressively more common and happens almost always where as before I would get some drive time in before it cut the power out.
any suggestions on where to start hunting for this?
thanks
Old Jul 11, 2010 | 12:47 PM
turns out the insulation around the wires running from the distributor to the ignition module had exposed ground wire. The insulation got burnt off by a previous incident and it was laying down close to the exhaust manifold. problem solved.
Old Jul 12, 2010 | 09:18 AM
krytellan's Avatar
Can you be more specific about the wires? Was it the ground wire leaving the distributor? Based on info I have there is no direct connection from the distributor to the igniter.
Old Jul 12, 2010 | 10:10 AM
thook's Avatar
And, you know.......that's just what I was going to suggest....
BushPig
Oct 29, 2022 06:26 AM
Sleaker
Aug 26, 2020 06:03 AM
ryerye13
Jul 14, 2015 08:27 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
mlavery85
Jul 12, 2015 10:33 AM
