3.0 Low Idle When Stationary
Old Jul 6, 2010 | 08:06 PM
95blackToy's Avatar
I have just recently noticed at times when my truck is idlingmy RPMs will drop to about 500 and sometimes lower. If i give it a little bit of gas and let off it will do fine. it just started happening a few days ago. Today i replaced all of my vacuum lines because i had a few cracked ones, but it did it after that also. Does anyone have any ideas what could be happening?
Old Jul 7, 2010 | 01:11 PM
95blackToy's Avatar
no one here has any clue...
Old Jul 7, 2010 | 01:17 PM
iamsuperbleeder's Avatar
could be a number of things to be honest
TPS, AFM, IACV, fuel pressure regulator, and so on and so forth...
check your intake tube for cracks and leaks as well
Old Jul 7, 2010 | 01:21 PM
norcal707's Avatar
tps....the the throttle position sensor...the easy way to do it if you have a problem with this is to disconnected and run the engine... if the engine still doing whatever is doing then the tps is good and it is something else......P.S. please let us know what you drive, year, model and engine.....I am assuming you are driving the truck you have in your avatar.
Old Jul 7, 2010 | 01:26 PM
Fink's Avatar
Like the others said, it could be a lot of things.
Year, model, engine, mileage, any mods that you've done, recent maintenance that's been done, etc...
Fink
Old Jul 7, 2010 | 01:56 PM
95blackToy's Avatar
sorry guys, its in my sig so i figured that was fine but its a 95 3.0 just did all the vac lines a couple days ago and i did the head gaskets a couple thousand miles ago. i have a K&N but that has been there for a good while before this started. And just today it would drop at start up to about 400 and surge between that and 500 and that happened about an hour or two after i drove about three miles. And when i drove it around the block a couple times it idled fine at about 750 or 800.
myyota's Avatar
Pull the throttle body and give it a good cleaning, and then check and adjust the throttle body if needed.
Old Jul 7, 2010 | 02:02 PM
95blackToy's Avatar
alright il pull that off as soon as it cools down. the tps is right behind the the throttle body right? When i unplugged it it idled at 1100.
Old Jul 7, 2010 | 02:07 PM
thook's Avatar
X2, 3, and 4.
So, you disconnected and the idle went up. Did it even out? Have you driven around, yet, to see how it's affecting things?
Old Jul 7, 2010 | 02:08 PM
Fink's Avatar
I agree with the TB cleaning suggestion - I would also hit your MAF with a little cleaner while you're in there.
Fink
Old Jul 7, 2010 | 02:10 PM
95blackToy's Avatar
what does maf stand for? can i use carb cleaner for it?
Old Jul 7, 2010 | 02:17 PM
95blackToy's Avatar
no i just let it idle. but it stayed there. and i can go drive it but i was clean the carb and stuff wile i got the nose of the truck pulled into my store room of a garage
Old Jul 7, 2010 | 03:26 PM
95blackToy's Avatar
Does anyone know what the little plate on the back of the throttle body is. its a bronze or brass color and has a tear drop shape on it. Well all of the screws holding it on were very loose and the thing could have fell completely off
Old Jul 7, 2010 | 03:43 PM
Fink's Avatar
Is it the actual valve itself?
Does it rotate on a pin in the center?
Fink
Old Jul 7, 2010 | 04:16 PM
95blackToy's Avatar
no its on the back of the throttle body. cant really explain how it looks. im trying to get the picture of it on the computer from my phone.
Old Jul 7, 2010 | 04:55 PM
95blackToy's Avatar
alright finally got this thing to cooperate. here is what im talking about. the rag is just because it was hot, and that is with the camera on the firewall facing the grill and the plate is on the back of the throttle body. the rag is on the surface where the throttle body connects to the plenum. http://s993.photobucket.com/albums/a...9.jpg&newest=1
Old Jul 7, 2010 | 05:21 PM
here let me help you with that
looks like just an access point to something? did tightening it back up fix the problem?
I have no idea... not a 3.0l guy
Old Jul 7, 2010 | 05:49 PM
95blackToy's Avatar
didnt fix it but the motor doesnt do it as bad until it warms up a little bit. i have a small crack in my intake tube right at the throttle body but that has been there ever since i can remember and it has never had problem. could it be that my distributor needs to be advanced a little bit because if i recall the 3.0 is suppose to idle at 800 and now its at 700 or 750 could that cause a problem?
Old Jul 7, 2010 | 05:55 PM
norcal707's Avatar
did you drove your truck with the tps disconnected?
Old Jul 7, 2010 | 05:59 PM
95blackToy's Avatar
i didn't drive it but it idles smooth and no surges or anything at 1100 maby i could just leave it disconnected or buy a new one and adjust the timing. im thinking that may be my problem or how do you adjust them
