Rear Leaf Springs?? 2wd 4wd difference? interchangeable?
Old Jul 2, 2010 | 06:19 AM
xalier's Avatar
ok my brother has a 2wd toyota i think its a 87 or 88 model and the rear leaf springs have bit the dust from hauling heavy loads.. we cant seem to find any 2wd leaf springs around here.. i have found some 4wd.. i know that the 4wd will have an extra leaf or so but are the mounting spots the same? could we install 4wd leafs and it work but it would give the rear a lift?? any info is greatly appreciated.. just trying to figure out the best way of helping him out..
Old Jul 2, 2010 | 06:33 AM
xalier's Avatar
also i forgot to add is there a difference in 4runners and p/u's leaf springs if not could i use them and the same question goes for it about the difference in 2wd and 4wd..
Old Jul 2, 2010 | 11:37 AM
rattlewagon's Avatar
Youll have to change the center pin around. Or cut it off and get a new one. (4$ at napa) Not sure on the 2wd length but the 4wd length for those years was 43" If hes hauling heavy loads alot, the 4wd springs might be a better option for him anyway.
Old Jul 2, 2010 | 11:48 AM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
2wd leafs are 2+1, 4wd leafs are 3+1 and have extra bump stops on the wraps.
I just measured one of my leafs for you, it's just under 47" eye-to-eye not following the arch (if the leaf was flat it'd be over 47" eye-to-eye). The spring is not on my truck at the moment, and I am not near enough to my truck to measure what the length would be installed. I do know that my leafs are not very tired.
Old Jul 2, 2010 | 12:42 PM
xalier's Avatar
on the center pin cutting off are you talking about if i get 4wd leafs or if i get 4runner leafs?
so it sounds that the 2wd leafs are longer than 4wd if 4wd has 43s and his not arched are 47 wouldnt that make 2wd like 53s or am i going the opposite way?? keep the feedback coming
Old Jul 3, 2010 | 11:07 AM
sorry, 4runner leafs are 43. Dont know about the puckups.
Old Jul 3, 2010 | 11:11 AM
CitrusTheDragon's Avatar
I saw a truck that had 4wd springs on a 2wd truck and the back look racked but not bad.
Old Jul 4, 2010 | 09:15 AM
xalier's Avatar
so no one knows which leafs are interchangeable?
Old Jul 4, 2010 | 11:52 AM
Robert m's Avatar
http://www.generalspringkc.com/index...parent=40&pg=1
Old Jul 7, 2010 | 01:10 PM
xalier's Avatar
well i measured my brothers leafs and they are straight flat on his truck i mean slap wore out and they measured 48inches eye to eye i dont see any on the chart do you think his are 47s and are just measuring 48 becuase they are dead?? and his truck is a 89 model...
Old Jul 8, 2010 | 08:31 AM
xalier's Avatar
anyone?
Old Jul 8, 2010 | 09:44 AM
Robert m's Avatar
i would say the 47's would work and if anything you could use a longer shackle. but where does the center pin measure out to? that will tell you more then the total length.
also where are you located because 2wds are plentiful here, its the 4x4s that are like hens teeth.
Old Jul 8, 2010 | 05:50 PM
Spectacular post robert. I saved that chart! The pins matter because the tops and bottoms are different sizes, they might not fit if the pin it too big, go head, ask me how I know.
Old Jul 9, 2010 | 06:20 AM
xalier's Avatar
im here in ringgold ga, its right near chattanooga tn, so what about the pin??? which ones can i use or do i need to get a picture of his pin?
Old Jul 19, 2010 | 12:08 PM
xalier's Avatar
anyone?
Old Jul 19, 2010 | 02:35 PM
akaphilly's Avatar
it would be the same. i ran 2wd rears for a while. then added an add a leaf. might have pics
Old Aug 29, 2010 | 06:55 PM
jc72381's Avatar
I just replaced the leafs on my 96 4x4 with a set from an 89 sr5 2wd and they bolted right in, so I imagine the opposite would work as well. My old ones looked like a recurve bow so I got about an 1.5" lift out of the replacements. They measured 51" just like the table says so you might be able to look in 95.5-2004 years if you havenet solved by now
Old Nov 13, 2011 | 05:25 PM
binky_rutledge's Avatar
Sorry to raise this thread but I can't help but hijack in hopes someone here can lend a hand. I need new leafs on my '95 2wd p/u, I am looking at some old man emu springs which have the option of 43" or 47", I would want the 47" from what I am reading here, can anyone verify this?
Old Feb 15, 2015 | 08:13 AM
dmoney88's Avatar
I'm trying to replace mine right now in my 88 2wd 4spd and I found the chart posted above on the 4wd springs but I found a set of 2wd springs with these measurements and when I measured the ones on my truck the way the charts show. I come up with 20.875(7/8) from center towards the front and 26.375(3/8) towards the back and the 4wd ones are 20.5 and 26.750 which is very minimum difference but would cause the rear-end to shift back 3/8" now my question is wouldn't that reduce the strength of the drive shaft/transmission spine connection? here is leaf spring I found also a link in case anyone else is looking for springs, only place I've found with them...
http://thesuspensionking.com/catalog...roducts_id=478
79-83 Toyota Pick-up 2WD Rear Leaf Spring
[TOY16] $232.00
Click to enlarge # Leaves: 4 (3/1)
Measurements: 20-7/8x26-3/8
Old Feb 15, 2015 | 08:48 AM
dmoney88's Avatar
That leaf spring is supposed to be an aftermarket "super strength" leaf spring. Only ones I can find though.
