87 pickup broke frame
Old Jul 15, 2010 | 08:51 AM
brokevayota's Avatar
Thumbs down 87 pickup broke frame
what frames could i use or could i cut the back half off and work with my truck ... could i use one off a 87 pickup with a v6 or are the different or one off a 91 pickup with 4
Old Jul 15, 2010 | 08:54 AM
xxxtreme22r's Avatar
did you completely sever the frame in half or is it just rotted by the front leaf spring mounts?
Old Jul 15, 2010 | 08:58 AM
the round brace that hold up the gas tank were it goes through the frame broke into and on the driver side it broke at the rear spring perch its beyond patching or saving so any idea what frames i could get the back half off of
Old Jul 15, 2010 | 09:07 AM
I have no idea, but I had my frame patched above both spring perches. I was pretty bad if you ask me. When the guy put it on his lift he said the one side perch fell on it's own, meaning the only thing holding the spring in place was the weight of the vehicle. He said the other side wasn't too far behind.
If you look in my build thread you will see where it was patched and how much he patched.
I would think your gonna find the same issues if you found another frame. Good luck.
Old Jul 15, 2010 | 09:09 AM
i went to changes the 35's on my truck to new 33's and when i jacked up the rear end the tail section on the frame just went on up to lol and with just pushing up and down the whole section came off
Old Jul 15, 2010 | 09:19 AM
2DoorRunner's Avatar
I have a buddy at work who got a truck with a cracked frame for like 100 bucks.
Cracked right at the bed, so he cut the frame off, made the rear end of it into a buggy pretty much.
You could do the same thing, or a flat bed, or even bolt the bed up to it again.
Just take lots of measurements if thats the route you take.
Old Jul 15, 2010 | 04:46 PM
MudHippy's Avatar
An 84-88 pickup v6 or 4cyl, but long bed and short bed are different length back halves.
Or an 84-89 4Runner, if it's a short bed PU. You could also use a 90-95 4Runner, but you'd have to mod it for leaf springs instead of coils.
Old Jul 15, 2010 | 04:51 PM
whorider's Avatar
They are interchangeable as long as the wheel base is the same.
Old Jul 15, 2010 | 06:29 PM
I know I didn't say I knew, but aren't the leaf springs/coil springs different? I would think they wouldn't be a direct fit. ie 89-95 had different leaf springs and the 4runners forget which years had coils.
frames might be the same but the rear suspension will be different and will have to be dealt with I would assume.
Old Jul 15, 2010 | 06:57 PM
well have a 95 short bed pickup 4 cylinder frame thinking it will fit my 87 any ideas ?
Old Jul 15, 2010 | 07:59 PM
Question what frame can i use
have a 87 pickup 4 cylinder 4x4 frames rusted into . and wondering what frame i can use have a 95 4 cylinder 4x4 frame and was wondering will it work ?
Old Jul 15, 2010 | 08:03 PM
Dont start new threads, this could have easily been asked in your other thread.
Old Jul 15, 2010 | 08:07 PM
waskillywabbit's Avatar
Merged threads.
Old Jul 15, 2010 | 08:31 PM
well it wasn't and i need to no so maybe somebody can help me out thanks
Old Jul 16, 2010 | 04:25 AM
so here it is again maybe somebody could help me out ...got a 87 short bed pickup 4x4 4 cylinder framed rusted in 2 and have a 95 short bed 4x4 4 cylinder frame will the 95 frame be the same as 97 if not could i use the rear section from behind the cab mount back ? any insight would help
Old Jul 16, 2010 | 04:26 AM
same as the "87"
Old Jul 16, 2010 | 10:00 AM
Yeah i bet it would work. If anything, you might just need to relocate the dody mounts on the frame.
Old Jul 16, 2010 | 05:57 PM
well got another ? will a v6 tranny work on a 4
Old Jul 17, 2010 | 07:47 PM
any body no iv searched but cant figure out
Old Jul 17, 2010 | 08:03 PM
Fink's Avatar
Patience is clearly not one of your virtues.
Do some searching in the Engine Swaps section and you'll find your answer.
If you need the answers as quick as you make it seem then that is your best bet.
I'd also start being more appreciative to the members who are helping you out instead of complaining about not getting an answer.
Just a thought.
Fink
