1993 Toyota 4Runner Slipping
Old 09-24-2011, 10:42 AM
93yota4runner's Avatar
I've had a problem with my 93 4runner staying in high gear when you put it in drive. Once you put it in drive it revs up high and it will eventually catch it with itself and start moving. Usualy I put it in 1st then 2nd then drive to take off. The thing about it is that its been doing this for almost 4 years so I'm wondering if it really is the transmission because my thought is if it is the transmission then it wouldve already went completely out??? I've researched and found talk about a shift solenoid...
I was wondering if someone could shed some light on this..
Thanks.
Old 09-24-2011, 12:51 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Are you having any problems with the speedometer or odometer, as well?
Old 09-24-2011, 06:38 PM
no there has been no problems with those...
Old 09-24-2011, 11:09 PM
GO_BLUE!'s Avatar
did ya check your tranny fluid and/or change it (along with the filter) anytime recently?
Old 09-25-2011, 04:16 PM
yes I have changed the filter and fluid and still the same...
Old 09-25-2011, 04:42 PM
BMcEL's Avatar
Sounds like solenoids to me.
Old 09-25-2011, 04:44 PM
RedResistance's Avatar
Solenoids, possible cause, bad tranny oil pump.
Weidle
01-21-2019 05:39 AM
Gamble_STi
06-27-2015 07:54 PM
nyk08trx
06-18-2015 09:01 PM
JaredL
06-16-2015 04:47 PM
Quick Reply: 1993 Toyota 4Runner Slipping
