Oil Temp Gauge - always in the middle
Old Oct 1, 2011 | 09:40 AM
pholife's Avatar
Hi All -
Water Temp Gauge not oil temp gauge. Error by myself.
Regardless of motor temperature or water temperature, my WATER Temp gauge in my 3.0 3vze moves to the middle immediately.
On first start of the motor in day (morning), it moves to the middle.
Do I replace sender?
thank you in earnest.
Old Oct 1, 2011 | 09:57 AM
az_eaglescout_pilot's Avatar
If you do a search for "where does your temp needle ride" there is a whole thread covering this ....I would give you the link but I'm on my phone...good luck!
Old Oct 1, 2011 | 10:26 AM
jeetS's Avatar
I have the same problem and installed an aftermarket gauge..
Old Oct 4, 2011 | 08:40 AM
pholife's Avatar
thanks....i wanne keep things oem...any other leads...thank you!
Old Oct 4, 2011 | 08:53 AM
sb5walker's Avatar
Sounds like the sender, since the gauge rises upon powering up. But could be a bad/corroded wire or connection. Be sure to get the temperature sender, not the coolant temp sensor which is for the ecu and is a different animal. The sender is smaller.
Old Oct 4, 2011 | 08:54 AM
MaK92-4RnR's Avatar
when i first start my truck in the morning, its a little above half. when driven after awhile it lowers at idle, and then upon accelerating ( or cruising ) it stays a little above a quarter.
Old Oct 4, 2011 | 09:43 AM
93toyrunner2's Avatar
FSM has a page (BE-51) all about testing the gauge and the sender. Under Body & Electrical, Combination meter. See download link in my signature.
Old Oct 5, 2011 | 11:06 AM
pholife's Avatar
thank you thank you.....have a great day!
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
88yodabasket
Jul 13, 2015 01:32 PM
Poncho0206
Jul 10, 2015 06:21 PM
