HVAC control function doesn't change
Old Oct 4, 2011 | 08:32 PM
86454k30's Avatar
I have a 94 Toyota 4x4, NON A/C, no matter where I put the HVAC selector, lower, upper or defrost it only blows out the upper(A/C) ducts. Any ideas?
Old Oct 5, 2011 | 10:11 AM
shaeff's Avatar
Broken cable? Can you hear the doors inside the duct work flapping when you move the lever?
Old Oct 5, 2011 | 11:35 AM
tj884Rdlx's Avatar
sounds like the cable came off of the lever which moves the flaps. the FSM has illustrations of this, but you should be able to stick your head under the dash and find it.
i've had mine slip off and i put it right back on. sometimes it doesn't have to be 'broken' for it to not be working. hopefully that's the case for you.
Old Oct 5, 2011 | 11:51 AM
86454k30's Avatar
Thanks guys, I will check that out.
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
icentropy
Jul 14, 2015 10:23 AM
cyclist231
Jul 7, 2015 12:56 PM
