3vze oil cooler
Old Sep 25, 2011 | 05:07 PM
gottadog's Avatar
3vze oil cooler
I pulled my motor and have another block being built locally. Today I was pulling accessories and brackets off my motor and got the engine oil cooler off. couldn't blow through the coolant lines so I put one coolant hose in my garden hose and blew the crud out. I noticed some water leaking threw the hole the bolt goes through to mount it to the block. I'm not terribly familiar with the part, it honestly took a bit of search to find what it is. So I'm gonna say it looks like water is seeping through the fins, or tubes, or plates, not sure how its constructed but it looks almost like a motorcycle clutch, stack of plates.
Anyone know if these are rebuildable or replaceable (hopefully not through Toyota). Or possibly a kit to install either an additional filter or block it off. I don't mind a remote filter and oil cooler to do the job if I can get it blocked off.
Any experience or tips welcome.
Thanks guys.
Old Sep 25, 2011 | 05:14 PM
93toyrunner2's Avatar
Subscribed. I would like to find out about this as well.
gottadog's Avatar
I just thought that maybe it is leaking because it was out of the motor and the torque of the bolt keeps the parts together. I just don't want to install it and ruin the lower end.
Old Sep 25, 2011 | 09:18 PM
GDR's Avatar
GDR
That cooler always gets blocked up. It gets feed coolant from the block drain so what ever crud or rust that settles in the block goes right in the cooler. The coolant is self contained in the tube and fins. Coolant shouldn't be leaking through the bolt hole. Oil runs around the fins inside the container and through the bolt.
Where the cooler mounts is actually a oil filter mount.The block has 2 filter mounts. I have a 2wd so my cooler is in the front and the filter is in the back. 4wd is the other way around. If you have the room you can put another filter there. You just have to get the threaded nipple to put in the block for the filter. Any of the remote filter or cooler mounts will work too since it is a standard oil filter mount.
Old Sep 26, 2011 | 02:29 AM
gottadog's Avatar
Perfect. Thank you for that GDR. I'll just put an aftermarket oil cooler on that side. Guess I'll be calling toyota for that threaded nipple.
Old Sep 26, 2011 | 04:40 AM
TNRabbit's Avatar
It came stock on the trucks with towing package option; optional on all others.
Usually, you only have to replace the THREE o-rings in the unit. If it's rusted through due to inattention to the cooling system, it will need replacement.
As stated, you can replace it with an oil filter or other options (outboard filter system).
Old Sep 26, 2011 | 06:12 AM
gottadog's Avatar
Anyone knoe the secs on the threaded nipple needed for screwing on a filter?
Old Apr 15, 2012 | 11:19 AM
Levi2336's Avatar
Leak!!
I have pinpointed an oil leak to that remote oil filter on my 3.0 vze. I bought an o-ring kit hoping that will do. Anybody have any insider tips I should know about??
Old Apr 15, 2012 | 03:43 PM
Change both coolant bypass hoses while you have it off. Easiest way to get to it is to remove the drivers side tire, the rubber skirt, and work through the wheel well.
Old Feb 28, 2019 | 10:48 PM
Kalihi,HI's Avatar
I'm going to tackle this job soon. The FSM only says to drain the coolant, but do you need to drain the oil as well? Both coolant and oil pass through the oil cooler? Thank you for any help.
Old Mar 1, 2019 | 06:04 AM
scope103's Avatar
Yeah, what does the FSM know?
The level of the oil in the pan is below the cooler. (Just lay your dipstick along side the tube if you're not sure.) You'll drip out a little, but draining the oil won't change that.
But gee, if you're going to be lying under your truck anyway, wouldn't this be a good time to change the oil?
Old Mar 1, 2019 | 07:06 AM
Kalihi,HI's Avatar
Thank you for the quick reply. I'll plan to do an oil change at the same time...But I do need to drain the coolant though, especially if I'm planning to replace both hoses as well right?
Old Mar 1, 2019 | 08:38 AM
scope103's Avatar
Man, you're just not giving the FSM any love, are you?
No, you don't need to drain the coolant. As soon as you disconnect one of the hose, all of the coolant will drain out automatically. On your head.
(The level of the coolant is to the top of the radiator. The oil cooler is close to the bottom of the coolant system.)
Old Mar 1, 2019 | 10:57 AM
old87yota's Avatar
The more straight forward answer (without the sarcasm ) is yes, you will need to drain the coolant.
The oil cooler is not completely full of oil when the engine is not running, but it is full of coolant.
Old Mar 3, 2019 | 11:51 PM
om933's Avatar
Oil cooling
Hey while you're at it, does it look like aguy could install a few hose bibs to a divorced OIL COOLER.I think that is my next project either that or a air compressor driven off the engine. Thanks for the info, best whishes
Old Mar 9, 2019 | 09:15 PM
Kalihi,HI's Avatar
So I removed the oil cooler and the upper pipe/tube that connects with the smaller u-shaped rubber hose to the engine was full of orange/brown sludge and so is the pipe coming from the engine. I was able to clean out the oil cooler with brake cleaner and compressed air, but what is the best way to clean/clear out the pipe/tube coming from the engine? Pour distilled water down the radiator and hopefully it cleans it out? Any help is appreciated.
Old Mar 11, 2019 | 12:38 AM
om933's Avatar
It's usually best to drain & flush cooling system with a chemical cleaner before disassembly, just a lot easier. But bottle type brushes work well on piping and tubing. Amine is a good cleaner, that is if you can get your hands on it. Wire brushes and elbow grease. Have fun, and best wishes.
jashoeuh
Nov 18, 2024 08:08 AM
clok
Aug 1, 2015 09:42 PM
88yodabasket
Jul 13, 2015 01:32 PM
Coreyr384
Jul 10, 2015 11:13 AM
Snort
Jul 9, 2015 03:58 PM
