difference 91 3.0 and a 95 3.0
Old Oct 4, 2011 | 09:30 PM
heckler502's Avatar
I was told there is a difference between these two. I have a 95 3.0 long block I want to put in a 91 4 runner. If i use all the part off the 91 will it work. Any help is welcome
Old Oct 4, 2011 | 11:14 PM
IngSoc's Avatar
If any thing its not going to be the engine its self but the injecters and other plugs to the harness. Just did a 3.0 swap on my buddies 4 runner and we ended up having to splice all the cab to ECU plugs to so the cab harness worked. If any thing I belive in 95.5 is when they started with the 3.4 as well. Either switch out ALL the sensors on the engine so your harness will fit them or swap out the whole cab harness. If you got the go-nads then cut n splice but thats risky business right there.
GL
Old Oct 5, 2011 | 06:48 AM
waskillywabbit's Avatar
No difference. They should equally suck
:wabbit2:
Old Oct 5, 2011 | 07:23 AM
MaK92-4RnR's Avatar
Theres no difference to the motor itself except the timing belt assembly... ( its hard to explain. The belts are the same, but the assembly to take it on/off is different ) Other than that, they're exactly the same. the only difference is what is under the hood... cruise control, fuse boxes, abs / non abs. stuff like that.
Old Oct 5, 2011 | 08:01 AM
heckler502's Avatar
Thank you everyone for you info. And yes waskillywabbit it.is going to suck maybe in a few year I'll get to put the ls1 motor in I want but have to do this way cause this is cheap and has fallen into my lap
Old Oct 5, 2011 | 08:13 AM
captainslow's Avatar
I just discovered this... I have a 90 and mine didn't ad up when looking at manuals. The earlier years have the no.1 idler pulley with a spring as the tensioner and the newer ones have a tensioner built into the fan bracket.
Also the "No.2 Idler Pulley" where the water outlet is attached mine is different than other manuals I've seen, I have a bypass hose.. would this present problems for coolant lines if you were changing things?
Old Oct 5, 2011 | 06:05 PM
ToyotaViejo's Avatar
There is also a difference in the distributors among the various 3.0 engines. There are two variants, and I think 88-91 and 92-95 define them. Different harnesses, and different shafts. One is interchangeable with the other in one direction, but not the other.
Old Oct 6, 2011 | 07:53 AM
GDR's Avatar
GDR
The early distributor has a pilot shaft on the end of the drive gear that goes into a machined hole in the head. The later ones do not have this so the hole in the head is not finished.
About the only option is to cut the end of the shaft off a early distributor if you want to put it in a later head.
Old Oct 6, 2011 | 09:38 AM
93toyrunner2's Avatar
The earlier one also has a pigtail with a connector coming out of it, vs. the newer one has a connector on it.
Old Oct 6, 2011 | 09:45 AM
BMcEL's Avatar
Good info here:
http://www.enginebuildermag.com/Arti...ta_30l_v6.aspx
Old Oct 6, 2011 | 09:49 AM
BMcEL's Avatar
Old Oct 8, 2011 | 08:01 PM
GDR's Avatar
GDR
Originally Posted by BMcEL
Cylinder heads
The cylinder heads are unique from left to right due to a spot for the distributor, although you can convert the heads by changing the caps and line boring the cylinder head. The early cylinder heads (’88 through ’90) had a smaller pilot hole for the distributor than the later ones which were 10mm.
To make a universal application, some shops have successfully machined the pilot holes to 10mm to fit later applications. This can be done without any problems if used on an earlier application with the smaller piloted distributor. The left and right camshafts did not change throughout the life span of the motor.
I'm not too sure about that information on the pilot holes. I only see one part number for the distributor from Toyota and the aftermarket for 89-91. Its also odd that they didn't mention the 92+ that has no pilot shaft.
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
tobylab
Jan 18, 2016 07:06 PM
Linked2002
3.4 Swaps
7
Dec 15, 2015 01:31 PM
Gone Fission
Jul 31, 2015 03:58 AM
tobylab
Jul 12, 2015 12:53 PM
