no crank, 87 4runner 22re
Old Sep 25, 2011 | 11:52 AM
knobs's Avatar
So my rig just randomly started doin this, I crank it and I get the most minimal or no cranking at all and it makes the ticking noise as if I had a dead battery, replaced starter and starter wire, don't have access to a voltmeter till tomorrow so I can't check voltage at the starter solenoid signal wire, all my grounds seem fin and I've got a 4-00 ground wire off the battery, im totally stumped for time being, any ideas?
Old Sep 25, 2011 | 03:06 PM
RedResistance's Avatar
The positive wire that comes from the relay box under the hood to the battery, check for cracks and corrosion. How new is that starter? Take the solenoid out of it and check the plunger contacts. Just the three screws on the back of it.
Old Sep 25, 2011 | 03:11 PM
knobs's Avatar
Ya that positive wire is pretty tore back, ill check that, thanks
Old Sep 25, 2011 | 03:18 PM
Lucky for me the only Toyota I've ever had this problem on was my Supra. It was that positive wire on mine, and resoldering a new one fixed my issue. Lemmie know if that fixes it.
-Shawn
Old Sep 25, 2011 | 10:37 PM
knobs's Avatar
Ok so I got ahold of a voltmeter, checked everything, the only thing odd I could find was at the solenoid plug on the starter I was getting 3 ohms of resistance, is that too much?
Old Sep 26, 2011 | 09:09 AM
Yes, there should be less than .01ohms. how did you have the ohmmeter hooked up?
Old Sep 28, 2011 | 10:05 AM
knobs's Avatar
i had it between the pos battery terminal and the signal wire, probably wrong but i am totally pullin my hair out over this!
Old Oct 1, 2011 | 01:36 PM
knobs's Avatar
Anyone?
Old Oct 1, 2011 | 05:13 PM
knobs's Avatar
Scratch that, got er dialed, the one ground I didn't check, THE BLOCK GROUND! Duhh, thanks for the input redrisistance
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
redneck17
Jul 17, 2015 07:44 PM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
