Impact gun on exhaust manifold studs?
Old Oct 2, 2011 | 07:31 AM
mmcpeck's Avatar
Just replaced my whole exhaust from the manifold all the way back, 3VZE. I tightened the down pipe from the manifold as much as I could with a 3/8" ratchet, but not sure if it's tight enough.
Is there a torque spec for those 3 nuts/studs?
Would using an impact gun on them, giving them a quick blast just to make sure they're tight, be a good idea or do I risk snapping the studs? Anybody ever use an impact on those nuts/studs?
Old Oct 2, 2011 | 08:39 AM
scope103's Avatar
"Connect the exhaust pipe to the LH exhaust manifold
with new gasket and 3 new nuts.
Torque: 62 N–m (630 kgf–cm. 46 ft–lbf)"
Why would you ever use an impact wrench to tighten anything? (at least anything you cared about.)
Old Oct 2, 2011 | 08:43 AM
DeathCougar's Avatar
The exhaust doesn't need to be super-mega-tight. As long as the flanges are in good shape, and you use new exhaust gaskets, you just need to get it tight by hand and you will be fine. If your exhaust leaks after you tighten it, you have a problem with the pipe/flange, not the torque.
Old Oct 2, 2011 | 10:33 AM
wyoming9's Avatar
Smile
I use my impact on as much as I can.
But one gets a feel for things after a few times.
Boomer8404
Sep 10, 2015 09:01 AM
shalom
Sep 8, 2015 10:02 PM
idadan208
Sep 7, 2015 09:06 AM
May-39
Sep 6, 2015 01:05 PM
