Low fuel light stuck on
Old Sep 25, 2011 | 04:39 PM
little_93_pickup's Avatar
Just took a drive up to walmart and about halfway there my low fuel light came on. Thought it was a little odd because the gauge was reading a 1/4 tank exactly. So to be safe threw 20 bucks in it. Now my gauge is reading just over 1/2 tank and the light is still on!! Any clues as to what it is?? Could this be the beginning of my pump going???
Old Sep 25, 2011 | 04:56 PM
RedResistance's Avatar
No, your pump is not going, the fuel sender is not part of the fuel pump. The low fuel light is an on/off switch in the fuel tank level sender that now appears to be stuck closed (on) on your truck. You could replace it or attempt to repair it with a little know-how.
Old Oct 4, 2011 | 05:39 PM
So the saga continues and i'm completely clueless now that the blinker is effecting it.. Light is still on and now when I turn on my left blinker it blinks with it. Starting to think there might be a short in the cluster.
Old Oct 5, 2011 | 05:47 PM
Hadmatt54's Avatar
You've probably got a bad ground on your cluster lighting circuit. The low fuel light and the signal light indicator as well as almost everything on that side of the vehicle have a common ground point located under the left kick panel. Take it apart and clean the connector and connection point and make sure it's tight.
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
Sep 4, 2015 09:27 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
