Rear Diff.... HELP!!
Old Sep 22, 2011 | 07:22 AM
Badger62811's Avatar
Exclamation Rear Diff.... HELP!!
So I just got home from the tire store... taking pics of my new tires and I find this...
What is going on here???? Did my seal give out?
Old Sep 22, 2011 | 07:27 AM
BigBluePile's Avatar
Looks like axle seal went....
Old Sep 22, 2011 | 07:33 AM
I can't even tell where its leaking from...
Old Sep 22, 2011 | 07:34 AM
waskillywabbit's Avatar
Rear axle seal/bearing most likely. If it was the diff it would be more on the diff.
:wabbit2:
Old Sep 22, 2011 | 07:35 AM
Indeed. Make sure you pull the diff breather and make sure its clear. Also, don't overfill the diff with oil.....
BMcEL's Avatar
x2.
Edit - wow you guys are fast.
Old Sep 22, 2011 | 07:42 AM
My thoughts exactly.. I'm multi-tasking... got auto parts stores up on the laptop and this thread up on the cell.. finally read Wabbit's reply and I got a few more after that. thanks a bunch...
Now what parts do I need? I may not be the most mechanically inclined, but I can figure things out... just trying to look up replacement parts and can't figure it out...
Old Sep 22, 2011 | 07:46 AM
BMcEL's Avatar
Axle seals are a PITA and bad bearings can cause them to fail prematurely. You'll need a press to do it the right way, but if you search you'll find other methods.
Old Sep 22, 2011 | 07:49 AM
so pretty much what I'm gonna need is...
http://www.autozone.com/autozone/par...mString=search
and some rented tools??
Old Sep 22, 2011 | 08:01 AM
BMcEL's Avatar
I'd get the parts from Toyota.
Great write up here.
Old Sep 22, 2011 | 08:09 AM
Well it looks like I've found the source....
Other ideas?
Old Sep 22, 2011 | 08:11 AM
GAH I don't even have a wrench big enough for the filler..... Anyone know the size right off hand??
Old Sep 22, 2011 | 08:12 AM
Reseal the diff.
Toyota black FIPG.
Easy.
:wabbit2:
Old Sep 22, 2011 | 08:13 AM
24 or 25mm depending on how used it is.
I replace all mine with low profile round plugs that have 10mm Allen insert.
:wabbit2:
Old Sep 22, 2011 | 08:18 AM
badattitude's Avatar
Get a 6 sided socket, not a more common 12 sided socket to remove the fill then drian plugs. A 6 sided socket will prevent you from rounding the corners on the fill plug.
I use a 24mm on my 1999 4runner.
Old Sep 22, 2011 | 08:19 AM
OK so it's really not as bad as you all thought it was?
Old Sep 22, 2011 | 08:21 AM
OK well I'll start there. Definitely cheaper than a $200 seal set. I'll drain it, clean it up, seal it, refill it, pray that's the problem.
135,000 miles and the rear diff hasn't been touched anyway... shame on me..
Thank you thank you
Old Sep 22, 2011 | 08:31 AM
Got a brilliant idea... got a 4 way tire wrench.. only goes up to 23mm though guess I gotta buy one.. and a 1/2" drive ratchet... bummer
Old Sep 22, 2011 | 08:36 AM
BMcEL's Avatar
Originally Posted by Badger62811
The oil on the bottom of the axle tube and brake still point to axle seal...I'd at least pull the drum and have a look.
Old Sep 22, 2011 | 08:40 AM
ok ok ok fine fine fine enough standing around at the tail gate talking about it... I'll jack her up and take a look....
Socket is $6
Ratchet is $20
FIPG is $13.70
New diff fluid $??
