upper a arm not realeasing??
Old Sep 29, 2011 | 04:00 PM
BUST'EM504's Avatar
How can I get the upper a arm to release. will the torsion bars being to tight cause it not to release?
Old Sep 29, 2011 | 04:46 PM
xxxtreme22r's Avatar
??? What are you trying to do?
Old Sep 29, 2011 | 04:47 PM
wii_tarded's Avatar
What are you trying to do? With the weight off of the front end, the torsion bar will pin the upper A-arm down against the bump stops. You will need to loosen the torsion bar bolts, and more than likely they will break.
http://www.toyotapartseast.com/compo...-03-11823.html
this site should have the bolts to replace the broken ones. OEM Toyota.
Be careful when loosening the bolts, some members have had the top part puncture the bottom of the cab.
Old Sep 29, 2011 | 04:51 PM
I be one of them.
Old Sep 29, 2011 | 08:20 PM
BUST'EM504's Avatar
I was putting spacers on and the control arm would not go up but I figured it out. I had to put shims under the bump stops and it worked great
Old Sep 29, 2011 | 08:28 PM
BUST'EM504's Avatar
Thanks for all the responses fellas pics will be up soon
ladybugRC
458
Aug 21, 2020 10:41 AM
bradahman
Oct 1, 2015 09:24 AM
ktm192k
Oct 1, 2015 08:47 AM
crash813
Sep 27, 2015 07:15 AM
Project90
Sep 24, 2015 11:40 PM
