91 22re no start
Old 02-22-2011, 12:37 PM
matt82's Avatar
91 22re no start
Hey guys. I'm new to toyotas and I'm having a no start problem. Recently replaced head gasket, got everything reistalled, timing set at 5* BTDC and the engine will not start. It turns over fine just will not start without gas being sprayed in intake. Can spray gas into throttle body will run for a few seconds then quit. Any help would be greatly appreciated. Thanks in advance for any help. Matt
Old 02-22-2011, 12:53 PM
justin_4runner's Avatar
fuel pump working? if not check the afm i think... the meter on the intake tube? is it pluged in? do a search on here and u will find some that about this type problems and what the fix was.
Old 02-22-2011, 01:21 PM
toyota4x4907's Avatar
Was it running before the head gasket work?
Did you check that the injectors are plugged in? Is the AFM plugged in?
Old 02-22-2011, 06:37 PM
matt82's Avatar
yea it was running when I took it apart and I reinstalled everything back the way it was. I jumped the turminals (can't remember their exact names) and the pump runs but it's just not getting fuel to the cylinders. Oh and I have an update on it. I was working on it today and it backfired while trying to start it and the entire engine bay burst into flames engulfing the ENTIRE engine bay in flames and melting alot of plastic. Can anyone tell me why it would backfire? I also know there was a fuel leak somewhere due to the size of fire
Old 02-22-2011, 06:47 PM
sb5walker's Avatar
Did you connect a vacuum hose to the side of the fuel pressure regulator? (the lower, larger fitting?) That's the fuel return line and fuel comes out of it. I heard of someone connecting vac to that once & it started a fire.
Old 02-22-2011, 06:54 PM
matt82's Avatar
I don't think so. I know it melted all my vacuum hoses so now I've got to replace them AND possibly find another wiring harness. The worst part is I STILL don't know why it wouldn't start
Old 02-22-2011, 07:31 PM
sounds like timing might of been off 180 out. and vacuum lines not hooked up right.
Old 02-23-2011, 12:40 PM
matt82's Avatar
I got an update for you guys. I accually sold the truck today. I can't afford to fix it so it had to go, but I'm looking for another pickup or 4runner 91 or newer
bigjstang
08-25-2021 12:41 AM
Yota.Jay
07-23-2015 08:08 PM
bryan34w
07-06-2015 05:53 PM
colinmil
07-06-2015 04:03 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 91 22re no start
