overheating after front end collison
Old Feb 20, 2011 | 04:57 PM
skoti89's Avatar
well, I rear ended my brother in law up in the snow. couldn't stop at all. I hit him doing about 15 to 20 mph. It pushed my body back an inch or so on the passenger side and cracked my radiator. It was just dripping coolant a little bit after the crash. I was able to get home and winched the body back to normal and connect the body and frame back together with the 3 inch body lift spacer too. I also just replace the radiator and topped it off.
I started it up and it seems to be running really hot and the fan isn't kicking in. Is there something that I could be missing? I don't know if my gauge is working or ever has. It says its cold in the morning, then shoots up to under halfway after 5 minutes of driving. never moving from that same spot.
IS there something else I should be thinking about or considering, or should worry about? The frame seems fine and the engine seems ok. What happened was the rad pushed back and the fan punched a circular hole in it. The fan was working all the back home (iheard it hitting the fan lol) it was also working at home before I replaced the rad.
Thanks. Any help appreciated.
Old Feb 20, 2011 | 05:02 PM
justin_4runner's Avatar
sounds like u still have air in the system. try burping it...
Old Feb 20, 2011 | 05:21 PM
Zelephant's Avatar
Could the collision have toasted the fan clutch, suddenly locking the fan up in the radiator? I was in a much more minor front end collision a few months ago, but I think it threw the fan shroud out off a bit, just enough to make the fan tap against it, and now, months later, the fan clutch is shot.
Old Feb 20, 2011 | 05:32 PM
skoti89's Avatar
how do i burp it?
Old Feb 21, 2011 | 02:46 AM
GeeVee's Avatar
Driving with the fan hitting might not have been a good idea. Hope you get it straight.
Old Feb 21, 2011 | 03:19 AM
peow130's Avatar
Originally Posted by skoti89
how do i burp it?
Pull the cap off the rad. Start the engine.
Fill rad with 50/50.. fill until level drops, fill more. Repeat.
Air bubbles will rise to the surface.
Just keep filling until it can't take any more.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
the1998sr5
Jul 16, 2015 06:20 AM
