Replacement for broken leaf springs
Old Feb 22, 2011 | 05:46 PM
jruh64's Avatar
My 1990 pickup has a broken leaf spring and I will need to replace the pair. Should be simple enough except I am not entirely sure if they are the stock springs or lifted (I am 3rd owner of this truck). I suspect it has a slight lift.
The truck has the factory 31" tires and has the apparently rare 7' longbed.
I would like to keep the same height as it is so I am wondering if I need stock springs or 1" or 2" lift springs.
Can somebody here tell me how to find out? Maybe if somebody knows how to measure stock height etc so I can compare. Or maybe just from seeing the photo below?
Thanks in advance, John
Old Feb 22, 2011 | 06:18 PM
dntsdad's Avatar
any markings on them?
Old Feb 22, 2011 | 06:35 PM
jruh64's Avatar
I couldn't see any markings on the springs but they are very rusty.
Old Feb 22, 2011 | 09:59 PM
Blue 89 Runner's Avatar
Judging from your first pic, I would say they have been re arched or something similar. How did it ride before the spring broke ?
Old Feb 23, 2011 | 03:42 AM
jruh64's Avatar
It's always been a very stiff ride, almost harsh.
thanks, John
Old Feb 23, 2011 | 11:39 PM
InvaderTrax's Avatar
Does it have aftermarket shackles? They look long
Old Feb 24, 2011 | 05:20 AM
jruh64's Avatar
The shackles are ~ 3-3/8" long, center to center. I don't know how long stock shackles are.
Thanks, John
Old Feb 24, 2011 | 06:29 AM
mt_goat's Avatar
This shows stock measurements for the front: http://www.off-road.com/trucks-4x4/t...ent-19258.html
Compare that to your front and then compare your front to your back.
A closer pic of the springs and shackles might help.
Old Feb 24, 2011 | 07:33 AM
RustBucket's Avatar
Wow, cool truck!
Have you considered something aftermarket like Old Man Emu?
Old Feb 24, 2011 | 08:45 AM
jruh64's Avatar
mt_goat, that's exactly the information I needed! Thanks a bunch! It also lists the part numbers for the torsion bar adjusting hardware which I anticipate breaking.
I measure about 15-1/4" from top of rim to fender lip (keeping in mind the chrome trim there). So the truck must be lifted 1-1/2" or 2".
Here are some (hopefully) better pics of the rear springs. You can see the broken leaf right above the axle on driver's side.
Rustbucket, thanks and i am also thinking the OME springs, they seem to be just what i will need.
Cheers, John
Old Feb 24, 2011 | 08:48 AM
mt_goat's Avatar
Yeah those look like stock shackles to me.
Old Feb 24, 2011 | 10:51 AM
RustBucket's Avatar
Also if you want to get fancy and do a little fabbing the 63" chevy leaf swap is a great mod. I have it on my 4Runner and it rides great.
88yodabasket
Jul 13, 2015 01:32 PM
jon.r
Jul 11, 2015 03:34 PM
Snort
Jul 9, 2015 03:58 PM
akaphilly
Jul 9, 2015 02:34 PM
Nickdigg
Jul 7, 2015 06:04 AM
