Bad gauge cluster?
Old Feb 24, 2011 | 08:59 AM
Tdavis03's Avatar
Unhappy Bad gauge cluster?
Ok so I have a 92 4runner auto v6 4x4, about 3 weeks ago the speedo and odometer went out, 2 days ago the fuel gauge went with it...
Which leaves me with 2 questions.
More than likely this means the cluster is bad, correct?
Is there anyway to tell if the speedo is cable driven or electric without pulling the dash?
I really hate to pull it all out, then put it back together, then do it all again once I get the correct part...
Any ideas of info/answers are GREATLY appreciated!!!
Old Feb 24, 2011 | 03:59 PM
stackedyoda's Avatar
Look on the end of the transfer case and see if there is a cable coming off the end of it, if yes then it's cable driven, if only wires are present then electronic.
Old Feb 24, 2011 | 04:18 PM
fierohink's Avatar
On my 5sp (yes I know you have an auto) there was a two-wire pigtail that crossed over the bellhousing from the passenger's side and plugged in to what I think is the Reverse Light switch, this chaffed one time and gave me fits. I'd blow fuses for the gauges, my speedo would work and then stop and then work again, jiggling wires near the dash and kick-panel-fuse box ran me in circles until I came across the chafe purely on coincidence.
Again i know yours is a slip-box but widen your eyes to just about anything.
Old Feb 24, 2011 | 04:25 PM
jakestolar's Avatar
This interests me. On my truck, My speedo works when it wants. other times it will just stick at some point and not move until I shut the truck off. At times my tach will not read correctly. Were you experiencing similar issues?
Old Feb 24, 2011 | 06:53 PM
Tdavis03's Avatar
Yea it would work at random for about a month, then just stopped entirely
Thanks every body Ill check it out when day light rolls around
mussy01
Dec 13, 2016 08:20 PM
gary4runner
Sep 24, 2015 12:53 AM
Esibnitsud
Jul 30, 2015 08:21 PM
Poncho0206
Jul 10, 2015 06:21 PM
