What is this part? Brake related?
Old 02-13-2011, 04:19 PM
HappyAdventure's Avatar
My left rear wheel started making a horrible metal on metal grinding noise after briefly parking on a hill, engaging the parking brake, releasing it, and driving off. It made the noise for about a mile while I drove home.
When I went back out to try and figure out what was wrong it did not make the noise until I put on the parking brake again (and released it, still made noise with the brake off). I drove around the block, and it stopped as this little part fell onto the road.
Any idea what it is? Where it goes? It did not seem to match any of the rear brake parts in the FSM diagram (4WD). Thanks!
Old 02-13-2011, 04:30 PM
corax's Avatar
looks like a drum weight - used to balance the rear drums
see it at the 6 o'clock position in this pic?
Old 02-13-2011, 04:32 PM
Nimyad's Avatar
well it looks like you had a nickel in there... couldn't resist.
Old 02-13-2011, 05:00 PM
Ricky B's Avatar
Dude, I've been looking for that thing since 1967. Thanx for finding it.......
(oh yeah, it's definitely a wheel drum weight. It should get tack welded back on----unless you're buying new drums)
Old 02-13-2011, 05:02 PM
Thanks corax, that would make sense. I will pull the wheel off and see if I can see the spot where it came off. Think I could stick it back on with JB weld?
Old 02-13-2011, 05:04 PM
And thanks Nimyad, I was hoping that thing I found in my pocket was worth something, maybe even $.05
Old 02-13-2011, 05:08 PM
Ricky B's Avatar
Hmmm, maybe. But you'd really have to scrape and brush and clean the dog poop out of both areas, and then let it marinate/set-up/dry for a day or three. Might just be easier to go down to your local olde skool brake mechanic shop and have them weld it back on correctly......
Old 02-13-2011, 05:47 PM
that is probably a better idea
Old 02-13-2011, 08:44 PM
iamsuperbleeder's Avatar
"Well there's your problem"
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
MTLroadierunner
07-06-2015 12:17 PM
wilbertd
07-06-2015 07:39 AM
zd92655
07-05-2015 04:25 PM
Quick Reply: What is this part? Brake related?
