Emissions help
Old Feb 27, 2011 | 10:29 PM
xXlGearheadlXx's Avatar
Emissions help
Any suggestions? i ve got a 91 Toyota pickup (3vze) I ve put a rebuilt engine in it and i haven't been able to get the emissions down on it. They are like super high. HC are around 3200 at idle if i remember right co's are about 10.00 and co2 are around 7- 10 ish. i ve also replaced all six fuel injectors, T.p.s. O2 sensor. all the temp sensors, Coil pack plugs and wires, distributor. Checked the operation of mass air flow (tested ok) Fuel pressure, igniton timing, i ve blocked off the evap system, and checked the cold start injector operation. I ve smoked it for any leaks in the intake system( did find some in the upper plenum which i just regasketed it and that took care of those. I ve done a compression test on it also which came to an even 150 across. Also i ve done pinpoint tests right at the computer (most of which were resistance tests) didnt find anything there. The cat was cut off so it didn't get ruined while its running so rich. I m kind of leaning towards the computer being shorted into a full rich mode. Really the truck seems to run good, maybe a little sluggish when u step on it but not too bad. Anyone have suggestions?
Old Feb 28, 2011 | 07:30 AM
fierohink's Avatar
How's your fuel milegage? If th computer is running open loop you should have crap for efficientcy. I know my truck has had emissions troubles in the past. 2 junk o2 sensors with a CEL on will do that .
But a big bottle (okay 1 size fits all bottle) of G2P, Garuanteed To Pass, works like a champ every two years when I go for VEIP.
Old Feb 28, 2011 | 10:44 AM
Well I ve changed the o2 sensor and its federal emissions so it doesn't have a rear one to monitor the cat gas mileage is around 14. Cel I m guessing ur talking about The mil lamp, its off and bulb check passes
Old Feb 28, 2011 | 10:46 AM
87hillbillyoter's Avatar
put a bottle of rubbing alcohol in the tank. seafoam it too. worked for me
Old Feb 28, 2011 | 11:41 AM
shaunneuhaus95's Avatar
my hydrocarbons are at 41.26, no cel, runs good, gas milage same as it ever was. taking it to mechanic this week. im outta ideas
Old Feb 28, 2011 | 11:54 AM
Its only got 5000 on the motor so there shouldn t be too much carbon build up. Its running super rich is the problem. Ha my emissions isn't due for a while but I want to take care of the problem. Also I failed to mention that at higher elevations like in the mountins it has a lack of power but aroundtown its great
Old Feb 28, 2011 | 11:58 AM
fierohink's Avatar
Okay if your hydrocarbons are that far out of whack and it's not burning through gas like an Escalade convention, I'd say either your EGR is totally jacked or your CAT is. Either way you could start with some rubbing alcohol, or seafoam, or water injection (personally not a fan), or Carb and Choke cleaner, or G2P. It could still be a mechanical failure if the EGR is stuck open, but I think you just need some cleaning.
Old Feb 28, 2011 | 01:48 PM
I ve taken the cat off as to not destroy it with the rich mixture I ve also taken the egr valve off and blocked the hole into the manifold and it still runs super high, I ve done that to both egr valves
Old Feb 28, 2011 | 02:06 PM
tim a.'s Avatar
Whats your fuel pressure?Regulator is first thing to check when engine is running rich but seems otherwise ok.
Old Feb 28, 2011 | 04:35 PM
fuel pressure is slightly high it s suppost to be around 36 but its running at 37 or 38
Old Feb 28, 2011 | 04:53 PM
kawazx636
Oct 6, 2021 03:03 PM
dbollier123
Sep 29, 2015 05:23 PM
Keithstoyota
Sep 27, 2015 07:29 AM
Boomer8404
Sep 24, 2015 01:12 PM
