3rd and 4th dropped out today (transmission problem)
Old Feb 18, 2011 | 05:18 PM
ohgood's Avatar
I've never (before today) had trouble with popping out of gear, or clutch slippage, or anything. On the way home from work, it felt like I missed a shift from 2nd to 3rd, so I just dropped it into 4th as I was going downhill. Well, 4th wasn't there either.
Any ideas if the marlin crawler thing has anything to do with this ?
1st, 2nd, and reverse all work fine. It's like 3rd and 4th are just missing- gone.
thanks for diagnosing, theorizing a fix for this perdicament over the intrewarbler.
Old Feb 23, 2011 | 02:55 PM
BigMike's Avatar
ohgood,
It is possible that you have an very badly worn out 4th gear fork that is no longer able to engage 4th gear. Also you may have a worn out center bearing plate that is causing the main shaft to walk into or away from each gear's shift fork causing the gear to self-disengage. This problem does affect 4th gear, as well as 3rd and 2nd in descending order.
When was the last time this transmission was serviced? Did you notice a metallic or shiny surface texture to the old oil? For instance, this is an example of a lot of metal mixed in with oil:
Thanks
Mike
Old Feb 23, 2011 | 02:56 PM
BigMike's Avatar
I forgot to ask, what is the Marlin Crawler thing
Thanks!
BigMike
Old Feb 23, 2011 | 08:54 PM
bend's Avatar
Thanks!
BigMike
It is the shifter bushing if I am not mistaken.
Old Feb 24, 2011 | 08:41 AM
BigMike's Avatar
Our Heavy Duty shift Bushings will not cause a transmission to pop out of gear as described here.
Would you mind reading this reply (#11) and then reply back with your thoughts?
Thanks
Mike
Old Feb 26, 2011 | 02:54 AM
ohgood's Avatar
Thanks
Mike
if you were refering to item description troubles, it was fine with me.
items arrived yesterday, dropped right in, and firmed up the new-to-me transmission nicely. the MC stickers are sharp, and including the huge one was a nicebonus. t
hanks ! 10/10 service !
Old Feb 27, 2011 | 07:48 PM
BigMike's Avatar
Saweeeet! I'm not sure if just the bushings will help this situation or not, so please keep this updated if needed!
Thanks!
BigMike
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
nick9455649
Sep 11, 2015 05:10 PM
Jnkml
Jul 6, 2015 01:20 PM
