4wd squeek/grinding noise
Hi.
i searched couldned find much help.. so i have a noise it only happens in 4wd.. i can unlock my hubs turn the 4wd on and i still get the noise... its a squeek or grind kinda like worn brakes or some metal to metal...
from my searching all i can think of is the spindle bushings?? or do you think the front drive shaft?? the brakes are new and its been fine all winter... dont get anynoise in 2wd and if i press the button to go from 4wd to 2wd i can hear the noise stop...
if its the drive shaft i assume its a u joint.. can u tell by looking if the u joint is gone?? will there be play if i tug it??
cause i have to drive it for a few days atleast in 2wd before i got a chance to look at it..
hi guys
hi mate did u find out wat the grinding noise was in the end? im having wat sounds like the same problem and iv just had the gearbox, transfer, diff rebuilt and also a new drive shaft but still the noise is there. any feedback u guys may have would be greatly appreciated. pat
genuinegemini
Aug 3, 2015 04:56 PM
Athansinis
Jul 27, 2015 08:38 AM
ripp96
Jul 25, 2015 02:32 PM
