hard to start but runs great
Old Feb 16, 2011 | 07:35 PM
dmaxxx21's Avatar
i have a 22re that is hard to start when cold and harder to start after driving it and letting it sit for about 20 min, and when i jumper the fuel pump it starts perfect. what do you think this could be? I will check the afm tomorrow and how do you test the open circuit relay?
Old Feb 17, 2011 | 10:39 AM
dmaxxx21's Avatar
Today I turned the key on and opened the flap on afm and the fuel pump came on, so could this be the relay or what?
Old Feb 17, 2011 | 12:35 PM
NW-Yota's Avatar
Subscribed! mine does this on occasion too.
Old Feb 17, 2011 | 05:48 PM
dmaxxx21's Avatar
No one has any idea or has solved this problem before?
Old Feb 18, 2011 | 06:45 AM
superex87's Avatar
Deff sounds like the relay is acting up.
Old Feb 18, 2011 | 11:10 AM
dmaxxx21's Avatar
Could the coolant temp sensor have anything to do with this cause I checked the relay with a ohm meter and it seemed to be within spec
Old Feb 18, 2011 | 05:55 PM
dmaxxx21's Avatar
tonight i put in a new coolant temp sensor and didn't help and also i was wrong about it starting with the jumper on fuel pump, it doesn't start good. I also tried starting and manually opening the flap on the afm and that didn't help so i pulled a plug it had spark, so does anyone have any idea what to do next? this is really starting to bug me. there was also 2 codes 22 and 71
Team420
Jan 12, 2021 04:57 PM
JF9243176
Oct 8, 2017 04:21 AM
Ichneumon
Sep 27, 2015 04:21 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
JF9243176
Jun 24, 2015 04:53 AM
