Modify Extra intake?
Old Feb 18, 2011 | 06:37 PM
jakestolar's Avatar
I have been tossing around an idea in my head. I see a lot of people like to switch the battery and intake. But I have noticed whether the intake is a factory set up or made to resemble a ram air intake it has very sharp bends in it.. My thought is to cut and paste the throttle body from the front of the engine and re-engineer it to come off at a 90 degree from the right side of the engine. I will have to dig further to see if vacuum ports will interfere. I also believe if the intake is on the right side the air will be distributed more evenly over the cylinders.
it is a 94 p/u. 22re 4x4. stock for now.
Interested in comments/ concerns
Thanks
Old Feb 18, 2011 | 08:00 PM
T_F_E's Avatar
I can understand where you are coming from but i dont think it would be worth your time. Eitherway its a 120ho motor or whatever
Old Feb 19, 2011 | 12:31 AM
myyota's Avatar
To much work for what little if any gains that you might see.
Old Feb 19, 2011 | 07:13 AM
jakestolar's Avatar
Thanks for the replies. I can see where everyone is coming from. But what have I got to lose?
Old Feb 19, 2011 | 07:31 AM
fierohink's Avatar
Just thinking out of my o-ring here, but it might be easier to swap the upper intake from a 3rz to your 22re. Then you would have an intake routing that was inline with the flow into the cylinders instead of perpendicular like the current set-up. And perhaps since it's an off the shelf item it would be easier to modify to fit.
Old Feb 19, 2011 | 07:46 AM
jakestolar's Avatar
Not a half bad idea!
Old Feb 19, 2011 | 08:26 AM
sebastianholmes's Avatar
subscribed. just the cool looking factor of that would be worth it!
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
Marsheen
Feb 17, 2016 12:29 PM
RatOmeter
Oct 22, 2015 03:17 PM
ia02
Aug 20, 2015 11:04 AM
Tacoma1313
Aug 17, 2015 05:44 PM
