continuosly rotating timing mark ???
Old Feb 24, 2011 | 06:11 PM
xlineapex's Avatar
Just finished up my A340H to R150F swap this weekend and decided to ckeck everything over, when i was trying to check the timing the timing mark on the crank pully continuosly rotated counter clockwise. i have been working on cars my whole life and have never seen this before. please help. this has me baffled
Old Feb 24, 2011 | 06:13 PM
xxxtreme22r's Avatar
stupid question but is your timing light hooked to the coil wire and not the #1 plug wire?
Old Feb 24, 2011 | 06:23 PM
xlineapex's Avatar
the timing light is hooked up to the battery and the #1 plug wire just like normal.
Old Feb 24, 2011 | 06:24 PM
xlineapex's Avatar
the cap and rotor are new
Old Feb 24, 2011 | 06:28 PM
this is interesting, not sure if it's possible on ours though: http://www.stevesnovasite.com/forums...d.php?t=152411
Whilst trying to time my car I noticed something quite strange.. I've got a 1967 straight 6 194cid on a 2 spd powerglide. I idled the car at exactly 500rpms pulled the distributor advance hose off and plugged the vacuum line. Aimed the light at the mark and saw it crawl up from the right and disapear over the left side.. After like 10 minutes it showed up again.. Its rotating counterclockwise. I tried moving the distributor and although it moved the mark left or right the mark still kept moving around by itself continuing its gradual rotation.. Do I have a vacuum leak or something somewhere?? Dirty carb, bad carb gaskets? Bad plug wires?? Where should I be looking I know this aint normal. I hooked my vacuum guage to the distributor hose to plug it.. I dunno if that makes a difference.. I don't think a vacuum guage leaks air into it.. This is so weird.
Sounds familiar to me. Check your balancer.The ring has seperated from the core that connects to the crankshaft. Ask me how I know! You will need to get a new balancer.
Old Mar 3, 2011 | 06:23 PM
xlineapex's Avatar
so the harmonic balancer was totally shot problem solved ! thanks for the help.
Old Mar 3, 2011 | 06:44 PM
no problem, glad you got that odd problem fixed.
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
crashburnoveride
Jul 10, 2015 06:39 AM
