93 22RE wont start
Old Mar 17, 2025 | 05:16 PM
ditypup's Avatar
93 22RE wont start
Hi people. Well my 93 4x 22REpup has been sitting this winter on a battery tender under a cover. I added 4 gallons of gas to it today and it won't start. This is very unusual for this truck, as it has always started right up.
Sprayed a little starting fluid into the air cleaner and it started and ran a bit then shut down. Is this pointing to no fuel delivery. maybe a bad fuel pump?
It's been a while since I have worked on it and never had this problem I'm old and don't remember all the things I used to know about these great little trucks.
Old Mar 18, 2025 | 03:07 AM
ditypup's Avatar
OK I guess I should pull the cold start injector and see if gas is spraying out when I try to start. And if I pull the gas line to it if there is pressure in the fuel line that would indicate that the fuel pump is working. Right?
It's not pulling any codes and that's a good sign.
carlost9322re
Feb 10, 2022 01:46 PM
osb40000
Sep 14, 2021 06:24 PM
chrismhartley
Aug 2, 2011 04:37 AM
Poor A$$ Stock '93
Jul 20, 2010 10:28 PM
airplanemech
Apr 22, 2007 04:34 PM
