Cowl louver removal
Old Dec 22, 2024 | 10:15 AM
3vz92's Avatar
Cowl louver removal
Hello , I would like to check.if someone previously remove the wipers cowl cover for cleaning purposes. Mine is full.of leaves and wanted to know before I remove it. Should I only remove the screws or there is any clips ?
Old Dec 22, 2024 | 12:03 PM
slacker's Avatar
remove wipers , and then there should be 3 screws (phillips head) and 2 clips on the ends
also , If your interested , we offer a smoothie .. it'll prevent this in the future
https://toyotafiberglass.com/wp-cont...othin-cowl.jpg
Old Dec 22, 2024 | 04:34 PM
Jimkola's Avatar
YT Community Team
5 Year Member
You have to open the hood to see the screws and clips mentioned above.
Once you take the nut off the wiper arms it takes a bit of effort to get off. It's a tapered fit. Sometimes lifting the arm and rocking back and forth works, other times a bit of leveraged upward force is needed.
I put fine screen on the underside of my cowl vents to keep leaves out
Alaska90
May 11, 2015 04:27 PM
BornChaos
Jul 18, 2012 02:41 PM
overKILL
Oct 27, 2003 08:53 PM
dope4Runner
Sep 4, 2002 11:31 PM
