1988 4Runner | Clutch Adjustment Issues
Old Mar 20, 2025 | 06:31 PM
Boogeyman's Avatar
Hello all. I have a 1988 4Runner and I replaced the clutch a while back. The truck has been sitting mostly. I notice that the clutch has no free play. So I located the stop nut and the push rod that goes into the slave. That little push rod will not move. Most of the videos I’ve seen it can be adjusted my hand. Just wondering if they a sign of a bad slave cylinder or what? Thanks for the help
Old Mar 21, 2025 | 10:03 AM
Boogeyman's Avatar
No one eh? Is this a dead forum?
Old Mar 21, 2025 | 08:44 PM
mholme's Avatar
Are you talking about adjusting the master cylinder behind the clutch pedal?
Old Mar 24, 2025 | 10:59 AM
Boogeyman's Avatar
thanks for the reply!
I want to adjust the free play as I have none. I’ve loosened the lock nut and from all of the examples I have seen, the long screw that goes into the master cylinder should be able to rotate easily by hand. Mine won’t rotate at all even with pliers. Someone wondering if the master cylinder is bad it needs to be replaced.
Thanks
Old Mar 24, 2025 | 12:08 PM
mholme's Avatar
It sounds like the pushrod is seized at the piston or clevis. Or both. Try pulling the clevis pin and detaching the clevis from the clutch pedal and see if you can rotate the clevis itself.
Old Mar 28, 2025 | 01:55 PM
osv's Avatar
osv
Thanks
i can't see how the end of the pushrod would have gotten attached to the clutch master cylinder, but i wonder if there is something distorted that's putting pressure on the area, like a broken clutch bracket: https://www.yotatech.com/forums/f116...ing-new-81611/
taking it apart as mholme described will tell you a lot.
coffey50
Aug 24, 2016 01:29 PM
Matin88
Apr 19, 2016 01:47 PM
thetrain
Dec 25, 2012 07:00 AM
going360
Jul 30, 2012 06:09 AM
