Battery and Brake Light Anomoly
Old May 12, 2025 | 11:49 AM
Samson3113's Avatar
SHi Folks
I have an 86 Toyota 4WD SR5 EFI Truck 22RE
Normally when you get a Battery and Brake Light on means that there is a battery or Alternator issue.
I checked my battery at cold and it registers 12.3 volts. When running, the battery is charging at 14.3 volts. I let the truck sit for 3 days and checked for battery drain and it still shows 12.3 volts.
Both Battery and Alternator seem to be fine.
This is the second time in 12 months that I have had these two lights come on and the second time they cleared by themselves.
Does anyone have any advice on what may be the cause?
I have no other issues with electrical right now with the truck
Thanks
Jim
Old May 12, 2025 | 01:03 PM
millball's Avatar
Sometimes when the alternator brushes grow short there can be intermittent charging issues that might light these lights.
Old May 13, 2025 | 02:04 PM
Samson3113's Avatar
Thanks Millball
Old May 13, 2025 | 06:55 PM
RAD4Runner's Avatar
Yeah this sounds like good place to start.
Old May 13, 2025 | 07:34 PM
Samson3113's Avatar
Is it difficult to check the brushes on the alternator. I assume I have to remove it and then find replacement brushes if I can
Thanks
JC
Old May 13, 2025 | 11:06 PM
millball's Avatar
Yes, the alternator will need to be removed for inspection
Brush cassettes for these Denso alternators are relatively inexpensive and easily sourced/
Old May 14, 2025 | 09:28 PM
Samson3113's Avatar
Thanks again Millball
Old May 15, 2025 | 06:36 AM
Discombobulated's Avatar
If you have the original still installed and determine it needs brushes I would recommend sourcing the brushes which as said above are available. Mine was long gone when I got my truck and I’m on my second reman since, so the third reman total keep the original!!!
Old May 16, 2025 | 11:53 AM
Samson3113's Avatar
Hi Discombobulated
Alternator is my 3rd, I believe. 10 years old.
Got it on Amazon. Was thinking about replacing it and not just the brushes. 10 years is pretty old so now I am wondering if other parts in it will fail
Jim
Old May 16, 2025 | 03:35 PM
Well that stinks, I’ve been disgusted with the failure rate of reman parts and so is my mechanic friend. Problem is if you give people the choice between a reman and OE it’s BIG BIG difference in price. The other issue is a lot of OE parts for our trucks are long discontinued so we have no choice anyhoo hope you get it sorted out
Old May 16, 2025 | 05:38 PM
RAD4Runner's Avatar
Originally Posted by Samson3113
Hi Discombobulated
Jim
Hi Samson....,
I have been happy with reconditioned OEM with Toyota Warranty parts from these three sources:
McGeorge Toyota (new name Ourisman Toyota)
Lakeland Toyota, and
Toyota Parts Deal
First two are dealerships with online parts store.
I had bought a starter, an alternator, and power steering gearbox among other things from them. Just compare prices and availability each time.
Old May 18, 2025 | 10:23 PM
Samson3113's Avatar
Oops..
I was incorrect in my years for the alternator. It is true i did buy a rem Denso from Amazon 10 years ago. But I purchased another Rem from Toyota of which a mechanic put in at the time. I will have to look at my logs when that was
I have purchased parts from some of those dealers you listed. I am mainly buying parts from RockAuto, Toyota Monster, Toyota Parts Deal, etc. Where ever the cheapest on the internet is.
Old May 19, 2025 | 02:24 AM
prcnctoyo's Avatar
Check the ground wire from the head to the firewall. I had an issue where the brake and charge light would light up, and the charge fuse would blow. Your's isn't blowing but ground might be a bad connection. I didn't find anything wrong with alternator or battery. The blown fuse happened a few times then stopped. Sometime later I found that ground wire broken.
Old May 19, 2025 | 07:08 PM
Samson3113's Avatar
Thks prcnctoyo. Appreciate the additional info
squeege
Apr 15, 2021 08:55 AM
A2theK
Jan 7, 2012 01:01 AM
db8gsr
Nov 8, 2009 07:30 PM
DeepSeaSnake
9
Jun 13, 2008 11:04 AM
callmekurt
Jun 7, 2005 01:30 PM
