Brake and battery light on
Old Jun 8, 2008 | 05:53 PM
DeepSeaSnake's Avatar
My brake and battery light is on when I start the truck and it stays on as until I hit 2500rpm then turns off and when it drops below 2500 it comes back on again. any ideas?
brake fluid level is good pedal feels fine voltage meter reads normal at just over the half way mark.
Old Jun 8, 2008 | 05:58 PM
Jay1's Avatar
Its your altnator.
Old Jun 8, 2008 | 05:59 PM
DeathCougar's Avatar
Alternator fo sho. Sounds like a dead diode.
You may also want to have your battery checked at the same time, just to be sure. A bad alternator can kill a good battery quite quickly.
Old Jun 8, 2008 | 06:03 PM
BAZ's Avatar
BAZ
Alternator fo sho. https://www.yotatech.com/forums/f116...lights-142719/
Old Jun 8, 2008 | 06:06 PM
olharleyman's Avatar
I just delt with that same thing this week myself and changed my battery saturday and so far so good but I also bought a good alt as a back up in case its not the battery.
Had the alt checked and its charging fine so I may have a used alt for 60 bucks what I paid for it as a back up in case.
Old Jun 8, 2008 | 06:58 PM
CJM's Avatar
CJM
You need an alternator, if you got a volt meter try using it and see what the charging volts are while running. Less than 13.5 or so (14 is better) and its history.
Or start it and remove the cables, it should still run.
Old Jun 8, 2008 | 07:02 PM
pyro's Avatar
Originally Posted by Jay1
Its your altnator.
x2 without a doubt
Old Jun 8, 2008 | 07:15 PM
4Crawler's Avatar
x3, change the alternator brushes:
- http://www.4x4wire.com/toyota/mainte...nator_brushes/
Old Jun 13, 2008 | 09:37 AM
Adam F's Avatar
Yep (I wrote that article)
In my case, I was actually getting 14v at the battery, so I put it off, thinking it was an electrical gremlin as I was having other gremlins at the time. But a day later the truck died on me driving down the road.
Fix it now before it leaves you stranded.
Old Jun 13, 2008 | 11:04 AM
Belize Off Road Team's Avatar
May not be the brushs, i had the same issue a few months back, the whole alternator was usless. i drove home at night with fading lights and a rapidly drainging battery.
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
