Intermittent play in steering wheel
Old May 4, 2025 | 04:28 PM
Hoodoo creek's Avatar
I have a 1994 2 wheel drive standard cabin truck. Parked, the steering is tight. Barely rotate the steering wheel and the tires respond. Going down the road, there's certainly play in the steering. Jacked up though, everything is tight...ball joints, tie rod, bearings and pitman arm. BUT, when the key is removed and the steering wheel locks, then suddenly there's about a 1/4 turn of play. What is causing that?
Old May 14, 2025 | 03:52 PM
osv's Avatar
osv
so if you open the hood and look at the steering box, you can see play in the steering shaft going into the box? but don't see play in the steering arm attached to the output shaft of the box?
AndrewQ
Jul 30, 2017 08:51 PM
derockus
Oct 30, 2013 07:51 AM
86yota2wd
Oct 23, 2009 08:56 PM
grn95runner
Apr 8, 2006 01:14 PM
Road Head
Sep 27, 2005 08:07 AM
