Price for rebuilding differential 1992 pickup 2wd
Old Dec 11, 2024 | 02:53 PM
otaim2005's Avatar
Hi guys,
I need my differential rebuilt on my 1992 pickup 2wd 22re 5 speed and the shop is quoting me 1300, is that reasonable?
Thanks!
Old Dec 11, 2024 | 03:35 PM
aztoyman's Avatar
Are they replacing just bearings or does this include a new gear set? Labor included? You can look at East Coast Gear supply or others and get the prices for new gears, bearings/setup kit. I personally recommend a solid pinion spacer instead of the crush sleeve but not mandatory. I'd ask what brand of bearings and gears too. Good luck with your rebuild.
Old Dec 11, 2024 | 05:24 PM
otaim2005's Avatar
Hey, thanks for the reply, that's all included with labor and new gears and everything. Not sure what brand I can ask. Does 1300 sound reasonable if all is included?
Old Dec 11, 2024 | 05:47 PM
aztoyman's Avatar
I build my own diffs so I don't know what shops typically charge. After looking up the prices for a new gear set and a setup kit, it seems kind of high to me. I could be wrong but I would be calling around and getting more quotes. The only way to know for sure if it's a fair price.
Make sure you follow the break-in procedure for new gears. Good luck and please follow up with whatever you decide.
Old Dec 11, 2024 | 05:48 PM
aztoyman's Avatar
To add, I didn't figure in labor to remove and install the diff. Not difficult but it is extra time.
Old Dec 12, 2024 | 06:56 AM
coryc85's Avatar
Are you sure you need new gears? If you aren't re-gearing to a different ratio, what makes you think you need new gears? Other thing you might consider is changing wheel bearings while the axles are pulled. Probably would not add much to your overall cost, axles are being pulled anyway to remove the diff, so just have to press old bearings off and new ones on.
Yotalover69
Jun 2, 2020 08:48 AM
Island_Yota
Jun 21, 2009 09:11 PM
team_primate
Jun 21, 2007 12:06 PM
95SASMudRunner
Jun 3, 2006 03:37 PM
Scofco
Feb 22, 2004 08:19 PM
