95 4Runner Code 52 after cutting off connector
Old Feb 21, 2025 | 11:41 AM
Jokawild103's Avatar
I found a connector under the throttle body that was falling apart and one of the wires was exposed. We decided to just go ahead and cut off the connectors and joined the 2 wires individually with wire connectors then used electrical tape to wrap them together.. Well it turned out to be the wiring for the knock sensor and now I’m getting a code 52. Do you think I mixed up the “polarity” when joining the wires or did I completely mess things up by cutting off the connectors? Thanks in advance…..
Old Feb 21, 2025 | 04:06 PM
Robert m's Avatar
Knock sensors are pretty much just microphones that listen for bad noises. Doing the splice could have introduced a lot of background noise or the ecu realized the sensor is bad
Id replace the knock sensor harness.
Old Feb 22, 2025 | 09:42 AM
Thank you so much…will do.
KindofaCritic
Mar 28, 2023 05:17 PM
954runner95
Apr 12, 2018 04:16 PM
mtrdrms
Jul 4, 2015 07:21 AM
buckz6319
Nov 17, 2009 08:26 PM
Saint_Berzerker
Jun 1, 2006 05:35 AM
