94 4x4 below-deck maintenance
Old May 28, 2025 | 01:54 PM
YotaYotaYota's Avatar
5 Year Member
I'm having a shop do a transmission, differential, and transfer case fluid change. While they are down there, I'm thinking that they should also repack the front wheel bearings and thrust bush(ing?) and lubricate the propeller shaft. Could you suggest other related work that would be useful to perform? My truck has only 86K, but it's been a while since he has been in a shop.
Old May 29, 2025 | 05:30 AM
rattlewagon's Avatar
Sounds like you got the bases covered!
They could grease the ball joints if they have grease fittings on them.
If the brakes feel spongey it could be time for new fluid.
Old May 29, 2025 | 07:31 AM
5 Year Member
I'll add ball joints to the list (I don't know if they have grease fittings, though). I do have brakes on my list, even though they don't feel spongey. Thank you for your advice!
Old May 29, 2025 | 07:45 AM
Jimkola's Avatar
YT Community Team
5 Year Member
When i first got my 4Runner i changed every single fluid. I used a fairly generic gear oil in the diffs, trans/ transfer. Later on I changed out for Redline. The sound reduction was very noticeable.
Old May 29, 2025 | 08:50 AM
5 Year Member
I continue to use their MT-90 and 75W-90, as well!
Gogo
May 24, 2022 09:25 AM
uenvythis
Aug 5, 2012 12:12 PM
davestoy
Feb 21, 2008 07:48 PM
trx125
Jan 23, 2007 10:13 PM
ricoace
Apr 24, 2004 07:21 PM
