Surging/running rough 22re
Old Dec 4, 2024 | 08:13 AM
bosco's Avatar
Hey all! Stoked to be back! It's been a minute! My younger driving years were spent almost solely in 84-94 4runners and pick-ups but I've had a long hiatus goofing around with Syncro Vanagon's for the last several years. Now my 18 year old daughter has decided to follow in my footsteps and has scored herself a 95 4runner with a 22re and 5 speed. Needless to say I'm proud and jealous!!
Anyway, this truck was a bit of a project but is complete. PO said it basically just needed timing adjustment. Yeah right. So it runs, but surges terribly whether it's cold or hot. I can't set the timing cause I can't set the idle properly. I've done a smoke test and there's no vacuum leaks but smoke did eventually come out the top of the EGR vacuum module. Which I think is ok? I've adjusted the TPS into spec. Replaced the AFM. Made sure the timing chain/cam marks are correct and aligned with cylinder 1 at TDC. Plugs/cap/rotor/wires all new. Of course this is a late model 22re so there are miles of vacuum hoses. My next guess was to trace each one and make sure they're routed correctly. But I've also been reading a bunch giving me cause to think maybe IACV or EGR issues?
Here's a couple videos of it running. Yes, the pink valve cover is bleh. First one is a cold start and I was trying to test functionality of the IACV buy turning the idle screw all the way closed. But not sure if it gave me any info or not.
https://youtube.com/shorts/riuLuefWWNU?si=gFKtzg34II_37ced
Second video is warm and shows jumping the diagnostic connector ports brings the idle down appropriately but then shows the timing being a touch advanced and then stumbling as I turn the distributor to retard the timing. I can't get it to settle in to the 5* mark it's supposed to be at without it stumbling and hardly staying running.
https://youtube.com/shorts/2Y71pAgOw48?si=uAfva3xYDZDUaDph
Hopefully those are better clues for some of you gurus. Thanks in advance for your time and help!
Old Dec 4, 2024 | 10:44 AM
bosco's Avatar
Well wouldn't ya know it, as soon as the post for help, I figured out the issue! Did the block off trick to test the EGR. Ran great! So EGR fix it is!!
Luca Signore
Mar 5, 2021 04:37 AM
Jasper 83
Sep 5, 2011 04:49 PM
Charlie9422RE
Oct 19, 2010 06:26 AM
Dogpound13
Apr 12, 2010 02:41 PM
gte718p
Jan 25, 2008 08:45 AM
