Fuel Pump not getting power when turn key on
Old Jun 3, 2025 | 09:15 PM
DVWG's Avatar
1991 Toyota Pickup V6 3VZE Engine
Installed new fuel pump and does not run while cranking
Cannot figure out why fuel pump is not getting power after turning key on. Replaced the relays still no power. If I jump the fuel pump it turns on. Someone said it might be something with the mass air flow sensor. But I am stumped.
any Ideas?
Thank you
Old Jun 3, 2025 | 10:16 PM
millball's Avatar
Fuel pump does not necessarily run just because the key is turned to run.
Does the pump run while cranking???
Old Jun 3, 2025 | 10:53 PM
DVWG's Avatar
No the fuel pump does not run while cranking.
Old Jun 4, 2025 | 05:36 AM
scope103's Avatar
A) You don't have a Mass air flow sensor. You have a Volume air flow sensor (VAF). Different technology.
B) But you're close. You probably have a problem in your VAF-COR circuit. Here's everything I know about that: https://www.yotatech.com/forums/f116...-quits-312747/
kj1687579@gmail.com
Mar 27, 2022 01:00 PM
schaff
Dec 8, 2016 11:37 PM
sinneDBTB
Apr 3, 2012 07:25 AM
gnardawg4sho
Jul 30, 2011 10:47 PM
david28
Apr 4, 2007 06:51 AM
